Question about Intermec VectorWorks 10 Full Version for Mac
New 2008 VW program for me on ne macbook pro problem is i cant get to export vw drawing as dwg 0r dxf it goes through the steps but seems to save to a file i cant find - open or use i wish to save it to the desk top so can give to architects for there auto cad the message from the mac always caomes up the same no matter how i save the draing or want it to be stored "Macintosh HD:Applications:Vectorworks 2008.app:Contents:MAcOS-dxf This file already exists.Do you want to replace the existing file?" any tips my job is on the line
  • 1 more comment
  • tom8454 Mar 31, 2011
    TRIED THAT = BUT STILL SAVES TO MACOS FILE
    WHICH CANT BE FOUND NOT TO FLASH DRIVE OR DESK TOP OR ANY WHERE YOU NEED TO ACCESS.
    NOT SURE HOW TO CUT MY CAD DRAWING FILEA AND PASTE TO NEW FOLDER
    DO YOU MEAN COPY THE DRAWING AND PASTE TO NEW DRAWING
  • 2,427 Answers
Try exporting the document directly to a flash drive,, ps you need to save it first then export it do a removable disc.
Posted on Mar 31, 2011
  • 1 more comment
  • Rishi Roshan Ali Mar 31, 2011
    go into the folder, and select and CUT all files, paste them in a new folder,
    now if thatb works you should be able to save your document, if not then u have a corupted harddrive, follow the instructions here http://www.ehow.com/how_2091895_defrag-m...
    then try again.
    ps if it says anything about a file in use then close all programs and restart, Try reinstalling the program
    well cutting is basically copying it, pasting it somewhere else and then deleting it.
    then when the program tells you a file is missing, simply copy that file back to the directory.
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
How do i fix autocad? Please help!
You can fix this problem in two ways.
First: follow these steps
- Open the Registry Editor by typing "regedit" in the Windows 8 Search charm and selecting "regedit" from the Apps section of the search results.
- Navigate to the "HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R15.0\ACAD-1:405\AdLM\Type" registry key.
- Right-click on the registry key and click "Export."
- Choose a name to save the license registry key file as, along with a location where you want to save it, and then click the "Save" button.
But if it useless try the second way- DWG Fix Toolbox. http://www.autocad.fixtoolbox.com/
Dec 23, 2014 | The Computers & Internet
.dwg file corrupt?
Different solutions you may find out here:-
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/444-%E2%80%8Berror-cannot-open-file-open-cad-drawing-dwg-format - a lot of different opinions might be your saving.
BAK files are very important, explanation below:
Consider what AutoCAD does during a QSAVE (assuming "create BAK" is enabled)
1. It writes the contents of the editor to a temp file.
2. It renames the current drawing from .DWG to .BAK
3. It renames the temp file to the correct file name with a .DWG extension.
I don't see how you have had problems with BAK files since it's simply a copy of your last save. In fact, if you QSAVE twice in a row, then your BAK = the DWG.
OR
Third party software DWG Viewer Tool
But demo version for free:- http://www.dwg.viewertool.com/
Nov 06, 2014 | Autodesk AutoCAD Computers & Internet
True view corrupt file: I can load a drawing directly from an Email attachment but when I save the file and then try to open the same drawing from that saved file I get a 'Drawing file is not...
Given trouble can resolve with the help of dwg recovery. It work with big autocad files corrupted and deleted after power failures, viruses, malicious software. The software has modern user-friendly, agreeable interface.
Sep 26, 2011 | Autodesk DWG TrueView
Route for serpentine belt on a 2.5 engine
I cant find for an VW 2.5L, but thisis for a VW 1.8L, maybe can help you:
- Timing Belt DIY (pics included)
I hope help with this. Good luck.
Sep 03, 2009 | 2008 Volkswagen New Beetle
How do you lock a dwg file so it cannot be edited?
A COUPLE OF SUGGESTION
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2009 drawings. about $330.
CADLock, Inc. continues to create innovative solutions that enable you to maintain control of your intellectual property and share it with those who need it. We invite you to download and evaluate CADVault® for AutoCAD® to find out how digital rights management can work for you. THIS MAYBE PRICY also
Acme CAD Converter Acme CAD Converter is a dwg/dxf/dwf format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF,JPEG, DXF, DWG, SVG , PDF, HPGL etc., and also enable the conversion between DXF and DWG file versions (R2.5-R2005).
Apr 01, 2009 | Autodesk Map 3D 2006
DWG export files from Vectorworks 2008
go to applications>vectorworks and right click the application
logo, and click on "show package contents"
then
contents>MacOS-DWG>MacOS.dwg
if you open up that last file that is the one you are looking for.
you can take it out of there and rename it and it is as good as
any other file.
the only thing is that everytime you export the new file goes right
into that folder.
I havn't found any easier way!
Dec 10, 2008 | Nemetschek VectorWorks (1NNP1UPGVXWZBA)
Lost drawing file
Punch will open only PRO files or PSH files
You can open the DXF files with a CAD program or Corel Draw. regarding the BMP files, you can aopen them with almost any graphic program, including MS Paint
Jan 03, 2008 | Punch ! Super Home Suite (695985)
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
Intermec VectorWorks 10 Full Version for Mac Logo
187 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
