Question about Air Tools & Compressors
How much oil does the compressor need - Air Tools & Compressors
  • 126 Answers
There should be a mark just inside the filler tube or if it has a dip stick there should be a mark on it check ur owners manual if u still have it
Posted on Mar 31, 2011
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    What oil do I use for a 2 HP air compressor
    If it is the sort of compressor that needs oil (lots don't), you won't do better than obtain a can of dedicated compressor oil as produced by most respectable oil companies.
    Compressors don't operate at such high temperatures as engines or suffer such extremes of pressure as hydraulic oils and so it is best to use an oil formulated for the conditions found in a compressor.
    If you temporarily can't source a dedicated compressor oil I suggest you use a straight grade oil; SAE 30 would be about right for hard use but SAE 20 for short runs and light use.
    What is the application or use of z6000 compressor oils?
    The MSDS sheet on it may answer your questions.
    Mineral Based
    Compressor Oils are mineral based air compressor oil designed for use in many rotary screw, reciprocating and rotary vane compressors needing an ISO 100 oil of this type, providing up to 2000 hour oil drain periods.
    Synthetic Based
    Are a full synthetic, special, ashless, synthetic based oils, designed to provide extended oil drains in both oil injected and oil flooded rotary screw compressors. They contain a special shear stable synthetic base oil to help reduce deposit formation.
    http://www.mitsuiseiki.co.jp/Portals/0/images/catalog/pdf/Z6000%E3%83%BBCOMPRESSOR%E3%83%BBOIL-E.pdf
    Jan 13, 2016 | Air Tools & Compressors
    Oil capacity air conditionercompressor 2010 holden cruze
    the oil in an ac compressor is in the compressor on installation and does not need replacing or replenishing. The oil travels with the gas and is through out the system
    you may get the oil capacity of a new compressor but you will need the compressor make,model and check on line to the compressor manufacturer as Holden will not have that information
    Feb 12, 2015 | Holden Cars & Trucks
    Accumalator/drier do i need oil
    accumolator,condensor,evaporator all store some oil.compressor has oil as well.if you bought used compressor,you only had to make sure theres about 3-4 of oil in it,no worries,remove a plug on the body of compressor and drain the oil,too much oil in system will prevent it from cooling.
    Jul 16, 2013 | 1997 GMC Sierra
    How much compressor oil do I add when changing the ac compressor on a 04 expedition with front and rear ac?
    When replacing the compressor the dryer should also be replaced, you put 2oz of oil in compressor and stand compressor on pulley for 5 min, then after install turn clutch 10 turns to pump most oil out of compressor, the dryer should have 2 oz of oil also, if you are flushing the ac system out with a solvent then more oil is needed for the system, if your just replacing the compressor then 2oz in compressor.
    Oct 09, 2010 | 2004 Ford Expedition
    Specific oil for hitachi compressors ???
    They make compressor oil, but all you need is non-detergent oil, the little engine spins so fast that it will turn the oil into foam, real quick. I think 30 weight, single viscosity type stuff will do.
    Feb 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
    Makita MAC 5200 3 HP 5.2 Gallon electric compressor
    Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
    Feb 22, 2009 | Makita MAC5200 Electric Powered Air...
    Ac compressor oil
    First off is your compressor pre-lubed? to find out, remove shipping caps from ports and tip to side and see if any oil comes out. As a rule of thumb, The oil is sold in a small bottle pre measured for the entire system. 1/4 bottle per item (compressor, evaporator,condenser, and filter/dryer) The label showing cc's will do fine for your oil needs as the system will find its own level once activated. Oil continuously flows througout system. Need I remind you that when replacing compressor you should also replace filter/dryer so you do not repeat this job in two months.
    Aug 03, 2008 | 1997 Dodge Ram 1500 Club Cab
    Air Tools & Compressors Logo
    48 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
