Question about Miller Welding Tools
I have a problem with my miller bobcat 225g it has a onan 16 engine on it .ive been trying to figure this problem out for a while, but havent been sucessful. it runs and works good when its running but will die randomly, I replaced the fuel pump and the charging module and its still doing the same think, I also put a fuel tank to see if the fuel pump wasnt doing its job but it still dies, can somebody help me with this? And does any one know what the ohms on the ignition coil is, i would like to check that next....
3 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
97F350diesel
  • 1326 Answers
SOURCE: need manual for miller bobcat 225n
Millerwelds.com Owners manual. You can download any manual for any miller product they have ever made for free. Here is the link. Download to your pc/print out whatever works. i always save a copy of my welder to the pc for future reference.
http://millerwelds.com/om/o4434b_mil.pdf
Posted on Aug 09, 2009
Miller Bobcat 225G was sitting for about a year I put new gas new fuel filter new sparkplugs and cleaned out the carb it cranks good but wont start I have no spark to the spark plugs
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 08, 2017 | Bobcat Garden
I have a miller 1995 bobcat 225G with a onan motor with a external fuel pump and out the back of the fuel pump is a whole that oil is coming out of what would be causing this to happen?
it could be a stop solenoid hole or a simple oil filler hole that the plug has fallen out of
contact an onan service center and ask the service person what would be missing
Jun 18, 2016 | Miller Welding Tools
Location of oil switch onan motor miller welder
Hi Martin,
I do have this site that has manual for you in order for you to locate it and its function as well. Hope it helps.
https://www.millerwelds.com/pdf/spec_sheets/ED4-4.pdf
Apr 26, 2014 | Bobcat Miller 225 Welder Generator 907209...
SHOP MANUALS
http://www.millerwelds.com/om/o4434b_mil.pdf For the Onan engine
if you have the Robin, Kohler or other engine, just go here:
http://www.millerwelds.com/service/ownersmanuals.php?model
Scroll down to the bobcat 225 welders and select the correct or closest to yours as you can. your serial number did not cross.
For servicing the engine itself, I can find the specs, but Onan is quite tight with their manuals and discontinue a great deal of them so parts would need to be aftermarket in many cases. You might find hardcopy on Ebay, but the basics of teardown and inspection are the same across most of the flat twins.
Jan 20, 2012 | Bobcat Miller 225 Welder Generator 907209...
Need manual for miller bobcat 225n the engine is an onan performer 16
Aug 04, 2009 | Welding Tools
Miller bobcat 225g plus welding problem
May 06, 2009 | Miller Welding Tools
Welding Tools Logo
174 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
