Question about AOpen Computers & Internet
I have a newly installed ide to sata converter with a 160G HD but was not recognized in the bios or HD not present
  • 2,427 Answers
Set the the hard drive jumper to Master,, if that dont work try Cable select and lastly slave, Some converters require specific jumper settings.
Posted on Mar 31, 2011
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
Dear sir i am newly purchase acer aspire time line tg4820 notebook windows 7 already install but i am using windows xp supported design software so i am change xp but not install sir please help sir by...
Hi Satish,
the system is presently using the SATA as the native, go to Bios and change the SATA mode to IDE and you will be able to install the XP
hope this helps
May 25, 2011 | Acer Aspire One PC Notebook
My Gateway CX2724 will not install a fresh copy of XP on new Harddrive. HDD is a newly formatted, and the BIOS is set to recognize CDROM, HDD, and so on. The SETUP is still stating that it can not see the...
You need to go into the BIOS and change the SATA type to IDE and not AHCI. I had this same problem on my laptop. Once I switched it to IDE it installed XP no problem. I don't know if Vista or 7 work with it set to IDE mode.
Nov 28, 2009 | Gateway CX2724 Notebook
Booting Problem
Hi there.
You will need to open your BIOS settings, and change your boot sequence/priority so that it includes PCI cards. Save and exit, and see if it then boots.
If you need anymore help, or need me to clarify anything, I'll be happy to help.
Tim
Apr 24, 2009 | Sabrent Serial ATA (SATA) 1 External + 2...
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Recognize sata hd
No drivers are needed - it should have been seen right away. Check the BIOS to see the drive is seen in the drives tables, and if there, XP needs to have the drive setup using FDISK. The drive will not show under windows until a drive table is on it.
Sep 05, 2008 | Intel Motherboard
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
