Question about Sunbeam 2774 Blender
Need gasket - Sunbeam 2774 Blender
BONJOUR,
J'AI BESOIN D'UN JOINT D'ETANCHEITE POUR MON BLENDER 2774
J'HABITE TROIS-RIVIERES, CANADA O? JE PEUX EN TROUVER UN
MERCI
Posted on Jul 21, 2011
Need parts for blender bl2010bgc,gasket and bottom cover
Check with a small appliance repair station for parts availability.
Sep 27, 2016 | Blenders
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
-Colleen@MendingShed
Apr 02, 2015 | Krups 572 Power Xtreme VI Work Top Blender
Sunbeam 2774 Blender Logo Problem with the Sunbeam 2774 Blender I need a gasket for my sunbeam blender #2774.
The gasket is not available by itself, you need the blade assembly part number 123250-000-000 available from Sunbeam at 1-800-458-8407.
Aug 13, 2011 | Sunbeam 2774 Blender
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
Need a replacement gasket for the Cook power blender
Boy, I spent some time on this and - so far as finding an exact replacement on the Internet - I'm stumped.
But I'll tell you what I'd do, in your position.
I'd take the old worn (or split) gasket to Ace Hardware or True Value, and ask someone to match it up for you. Really, a gasket is a gasket. It's just a matter of the size, the thickness, and the "compressability" of the rubber (obviously, you'll want a soft rubber gasket). If you find one, you may want to buy two of them... just in case.
If this doesn't work, then get a square piece of rubber gasket material (Ace, True Value, Home Depot, etc.). You can either cut one yourself (use cups, jars, measuring spoons that are the right diameters to draw your two ring patterns), using an Exacto knife to carefully cut them out.
If you don't want to do this yourself, ask someone who's handy & who has a steady hand to do it for you. You can pay them with a freshly made smoothie.
Mar 03, 2011 | Cook's Essentials Smoothie Maker Work Top...
New gasket installed but jar still leaks...Does gasket go between jar and cutter or between cutter and screw base?
The gasket goes between the plate to which the cutter is mounted and the base of the jar. i.e., atop the cutter and contacting the base of the jar.
Charlie
Jan 12, 2011 | Waring Blenders
Where can I find a gasket for Sunbeam 2774 blender???
If you cannot find one, well in the "Old" days we used to make gaskets out of Thick Brown Paper Bags. Using the OLD gasket as a template simply trace around it & cut it out. Lightly Oil it and use it as normal. Usually works great, sometimes you need two, to get the thickness.
Feb 03, 2010 | Sunbeam 2774 Blender
Looking for a replacement gasket for the VillaWare
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have some gaskets. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at amylovescats2010@yahoo.com. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
Aug 15, 2009 | VillaWare 5785 Smoothee Bar Work Top...
83 people viewed this question
Top Sunbeam Blenders Experts
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sunbeam Blender Expert? Answer questions, earn points and help others
