Question about Casio FX-115ES Scientific Calculator
How can we do linear interpolation in casio fx-115es?
SOURCE: how can we do linear interpolation in casio fx-991ES calculator
how solve interpolation by casio fx 991 ex
Posted on Nov 28, 2010
SOURCE: Is there a "canned" interpolation function in the
(-19) + 9 + (-3)
Posted on Oct 25, 2010
  • 7993 Answers
SOURCE: how do i enter linear
You can enter equations of any type. Read the rest of the post. Keep in mind that if you are using the Solve( function X must be the unknown. If you are using the Table computational mode, X is the independent variable and Y the dependent one.
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 you proceed as follows.
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you enter the equation you are dealing with, and before pressing anything else, press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter. Once all non-X variables (if any) are given values, the calculator will return with the solution. You will see on the screen L-R= (should be zero if you are lucky).
Posted on Nov 16, 2010
SOURCE: Hello, I have a calculator
the mode key is giving error and the number keys are not working
Posted on Aug 02, 2011
Elessaelle
  • 122 Answers
SOURCE: solving linear equations in 3
Press key Mode, first select option 5:EQN (by pressing key 5), then option 2: a_nX+b_nY+c_nZ=d_n (by pressin 2).
Now input coefficients from equations in table (each column is for one variable), just type in number and press =, then use arrows to move to another cell.
Posted on Sep 05, 2011
How to do interpolation in Casio f2f-4800p?
Interpolation mannual in fx-4800P - Fixya
www.fixya.com/support/t22818601-interpolation_mannual_in_fx_4800p
Jan 11, 2014 - interpolation mannual in fx-4800P - Casio Rare Vintage Scientific question. ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
interpolate how can interpolate linear regression by casio ...
www.fixya.com/support/t22818666-interpolate
Jan 11, 2014 - interpolate how can interpolate linear regression by casio fx-4800P -Casio ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
how to perform linear interpolation manually and on casio fx ...
? 6:39
https://www.youtube.com/watch?v=rCVM6RWMjQ4
Jan 7, 2015 - Uploaded by Yabets Jab
In this video you can simply understand how to find a value of a given missing number in a table on Casio fx ...Missing: 4800p
Linear Regression on a Casio calculator - YouTube
? 6:25
https://www.youtube.com/watch?v=OGmHagjZPjg
Oct 31, 2012 - Uploaded by cpobyrne1
How to perform a linear regression on a Casio scientific calculator. Example uses a ... A Casio fx-83WA calculator is used for the demonstration. .... Lagrange Interpolation Easily Explained on Casio fx-991ES Calculator!Missing: 4800p
Jan 05, 2016 | Casio Office Equipment & Supplies
Is there a function for Linear Interpolation, if so, where do I find it? Thanks!
Sorry, I don't have that calculator, but let's see if we can work this out. "Linear Interpolation" means find the value of y for a given value of x from a line of best fit, within the range of values that you are given.
Hopefully, this helps. If not, let me know and we will explore more.
Good luck,
Paul
Apr 22, 2015 | Casio Algebra FX 2.0 Calculator
I forgot how to do linear regression on casio fx-115ES. Example: (1,2), (3,Y), (5,6). How can i solve for Y in casio FX-115ES?
Press [MODE][3][2]. In first column enter known x-coordinates (1 and 5), in second known y-coordinates (2 and 6). The solution you are looking for is in form Y=A+B*X where X=3. Your calculator computes A and B after you enter data. To calculate Y (which is equal to A+B*3 press [SHIFT][1][7][1][+][SHIFT][1][7][2][*][3][=]. The result should be 4.
If I helped you, please rate my answer :)
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
Solving linear equations in 3 variables by matrix method in casio fx-115ES
Sep 02, 2011 | Casio FX-115ES Scientific Calculator
How to interpolate in CASIO fx 991 ES
its simple
press mode
3;stat
2;A+Bx
l x l y l
l 2 l 4.6 l
l 4 l 5.9 l
press; AC
press;5.9
press; shift
press;1
press;7 (reg)
press;5 (comma)
press;=
u will get ans
Feb 08, 2011 | Casio FX-115ES Scientific Calculator
How do i solve a matrix?
What do you mean by "solve a matrix"? Find the inverse? Find the determinant? Find the solution to a system of linear equations? Within limits the fx-115ES can do any of these and more.
The procedures are described in the "Matrix Calculations" section of the manual. If you still have problems, please reply to this post specifying what you want to do.
Nov 18, 2010 | Casio FX-115ES Scientific Calculator
How do i calculate limits on my Casio fx-115es? Ex. lim x->3 for (x2'-0)/x-3
Sorry, but you cannot calculate limits of functions with this calculator. It does not have a Computer `Algebra System (CAS). For that you need a graphing calculator with CAS: Casio ClassPad 300, 300PLUS, 330, HP 48 GII, HP49 G/ G+, HP 50G, TI-NSPIRE CAS, TI89 Titanium, TI 92/92PLUS, TI Voyage 200 PLT. It is still a very good scientific (non graphing) calculator
However, you can calculate numerical derivatives, and numerical integrals, solve linear and non-linear equations.
Even though this post does meet your expectations, do not let that prevent you from rating it.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
293 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
