Question about Westpoint TV-203 1000 Watts Microwave Oven
MICROWAVE E02 ERROR - Westpoint TV-203 1000 Watts Microwave Oven
    Brigadier General:
  • 8,909 Answers
I would say you have a temperature sensor error. Either damaged or faulty sensor and would call an authorised repair service for a price to repair it.
Posted on Mar 31, 2011
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
What does this mean on my Samsung smh9151 microwave oven? -SE-
The SE error indicates a short was detected at the key pad. This could be a problem with the wiring (dirt at a connection) or a bad circuit board. If your microwave is under warranty, contact Samsung.
Since microwaves have high voltage, you may not want to try to fix this yourself. If you do, make sure to be careful. Some have fixed the error after unplugging the microwave. Then disassemble the microwave keypad area. Disconnect the various wires and clean all of the contacts. (Do one wire harness at a time so that you replace them in the right place.) Reassemble and plug in the microwave. Test if the SE error returns. If the error remains, then the control board needs to be replaced. To get the entire keypad and control board, seehttp://www.repairclinic.com/Shop-For-Parts/a6b160i468/Samsung-Microwave-Touchpad-And-Control-Panel-Parts . The board alone is here: http://www.repairclinic.com/Shop-For-Parts/a6b160i324/Samsung-Microwave-Control-Board-Parts .
I hope this helps.
Jan 16, 2016 | Samsung Microwave Ovens
E41 and does not work
If your microwave is displaying an error code cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker.
If the above suggestion does not work,and the error code returns, your microwave will require service.
Aug 19, 2011 | Samsung MW1080STA Microwave Oven
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
210 people viewed this question
Top Westpoint Microwave Ovens Experts
William Miller
William Miller
Tom Chichester
Are you a Westpoint Microwave Oven Expert? Answer questions, earn points and help others
