Question about HP PSC 2355 All-In-One InkJet Printer
165:hw_interrupt_hwv2.c - HP PSC 2355 All-In-One InkJet Printer
  • 3 Answers
Might be dried out electrolytic capacitors on the printer circuit board. If you feel adventurous you can check this yourself by removing the plastic cover around the power / USB connectors and then blowing warm air in to the circuit board with a hair-dryer for a couple of minutes. If everything's working now, you probably have faulty capacitors. Replacing them is no easy task though...
Posted on Apr 01, 2011
2 Suggested Answers
  • 3 Answers
SOURCE: error 0xb9000009 165hw interrupt hwv2.c
Might also be dried out electrolytic capacitors on the printer circuit board. If you feel adventurous you can check this yourself by removing the plastic cover around the power / USB connectors and then blowing warm air onto the circuit board with a hair-dryer for a couple of minutes. If everything's working now, you probably have faulty capacitors. Replacing them is no task for beginners though...
H-400 error on Sharp 165
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
May 29, 2015 | Sharp Office Equipment & Supplies
Hw and ch not coming on auto , will come on if reset but following day will not come on again until reset , there is no red light on , on the time guard does this have any thing to do with it?
Hw & ch in my vocabulary means Hot Water & Chiller. I have never seen this on a thermostat. I'm also assuming by time guard, your saying time delay. The time delay only goes into effect if there is a power interruption.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
HP PSC 2355 is stopping in the middle of printing. Then can't even get it to turn off. message )xb984489d and 165 hw interrupt_hwv2.c Can you help?
Just fixed a HP PSC 2355 that had this problem. Turned out it was caused by dried out electrolytic capacitors on the printer circuit board. You can check it yourself by carefully removing the plastic cover around the power / USB connectors and then blowing warm air in to the opening with a hair-dryer for a couple of minutes. If everything's working now, you probably have faulty capacitors. Exchanging them is another matter entirely, don't attempt this unless you have a good working knowledge of electronics!
Mar 31, 2011 | HP PSC 2355 All-In-One InkJet Printer
I am facing F2-04 error code in sharp AR-M 165
# - interrupt- C - Interrupt -press 16 press Print key then machine is ready.
Feb 12, 2010 | Office Equipment & Supplies
The same
youre showing a hardware interrupt code for the printer... check with HP on the specific by mfg website
Sep 14, 2009 | HP PSC 2355 All-In-One InkJet Printer
Dish washer displays pf code
PF is probably PE like mine, sometimes the bottome row of the liquid display doesn't work properly
PE is a Pressure Error - condition - The water level in Tub goes down during operation
Possible Causes
¥ The Circuit of Pressure Switch
shorted or disconnected.
¥ Pressure Switch is troubled or
disconnected
¥ The Controller is troubled.
¥ The Air Tube is kinked or damaged.
Possible solutions
¥ Repair or replace the Circuit of
Pressure Switch.
¥ Replace the Pressure Switch.
¥ Repair or replace the Controller.
¥ Remove the cause of kink or replace
the Air Tube.
Jul 18, 2009 | LG Dishwashers
I have LG dishwasher model LD 14AW1 I get error the message HE about 15 minutes into the wash cycle then the dishwasher turns its self off
HE refers to HEATER ERROR
The water is not heated
or the temperature in
the Tub is overheated
to over 95¡
Possible causes
¥ The Circuit of Heater is troubled.
¥ The Thermistor is troubled.
¥ The Heater is shorted.
¥ The Relay Circuit is troubled.
Possible solutions
¥ Repair the Circuit of Heater.
¥ Replace the Thermistor.
¥ Replace the Heater.
¥ Repair the Relay Circuit..
Feb 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
HP PSC 2355 All-In-One InkJet Printer Logo
972 people viewed this question
Seeker5211
Seeker5211
