Question about Refrigerators
Philips cyclic defrost 400L fridge, was moved twice in the space of a week. When it was switched on again it froze everything. Now, after a few days of settling down, it is still freezing everything in the fridge except the whats in the crisper. The temp setting is currently on .5. Is there anything else I can do to stop it freezing everything?
HVACRH20
  • 237 Answers
SOURCE: samsung side by side srs580dw stops freezing and chilling
Since the temps on the display don't show correctly I'd assume something is wrong with that. If the temps are sending info out that the unit is OK and at proper temp (when it's not) then the compressor won't turn on because it thinks the fridge is cold enough. Soooo... I'd suspect that control board. It's item 48 on this diagram http://www.partselect.com/Schematics/Maytag/SS10-2.gif
Posted on Jan 14, 2007
dididsaythat
  • 291 Answers
SOURCE: Fridge Problems
what model and make is it
Posted on Oct 31, 2007
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
SOURCE: Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Posted on Jul 22, 2010
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
My freezer doesn't keep ice cream frozen more than a couple of hours. Other foods are frozen, but some slightly 'soft' frozen. Up until a couple of weeks ago it would produce ice cubes regularly. Now if I...
YOUR DEFROST TIMER MAY BE BAD OR THE HEATERS ARE BAD. WHAT HAPPENS IS THE EVAPORATOR IS FROZE OVER WITH ICE AND CAN'T TRANSFER THE COLD . UNPLUG THE FRIDGE FOR A FEW HOURS (HAVE RAGS AND MOP READY) AND IT WILL WORK AGAIN TEMPORALLY . THE LESS YOU OPEN THE DOORS THE LONGER IT WILL LAST.. BACK IN THE DAY IT WAS CALLED DEFROSTING THE FRIDGE AND WAS DONE ONCE A MONTH OR SO
Jan 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
Mar 14, 2009 | Maytag MBB1956GES Bottom Freezer...
I have a Kelvinator Cyclic 501 Impression Series fridge. Model C501V-R. no matter what setting it is on everything is freezing - the door seals are in excellent condition.
I used a,Hair Dryer on mine that fixed it, had too do it twice though have not had a problem since, (it froze the entire Thermostat over), had my Fridge for over 30 years only ever replaced the seals recently, no other problems ever
Jun 11, 2008 | Refrigerators
Fridge not working
sounds like the defrost system is defective, frozen. possibilities are fan in freezer wuit or defrost heater open or defrost timer bad. try these first, if not fixed call.
Mar 28, 2008 | Refrigerators
GE Fridge/Freezer Having to turn temp up just to keep it cold
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
Refrigerators Logo
352 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
