Question about Ovens
E02 ERROR FOR IFB MICROWAVE OVEN AFTER 6MIN IN CONVECTION AND GRILL MODE WHAT TO BE DONE EVEN IF U RESET AND START AGAIN IT APPEARS AFTER 6MINS
  • 3 Answers
SOURCE: Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Posted on Dec 30, 2007
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    localwonder
    • 6784 Answers
    SOURCE: f9 error code while using the convection baking function
    This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
    Posted on Jul 30, 2009
    SOURCE: we installed kitchen aid microwave convection oven
    Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
    Chander Mehta
    Posted on Jul 03, 2010
    Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
    Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
    Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
    F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
    The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
    Jan 06, 2008 | Ovens
    My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
    I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
    Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
    I had to pull my oven out of the wall and ever since I did that, I get a message that says "Feature Not Available" on any button I hit. Is there a reset button or something?
    It's an error code that will not go away until a technician resets it. Quote straight from the manual :
    "The oven may detect a fault during programming or during operation. If a fault is
    detected, the message "Fault detected - press power to clear" or "Fault detected -
    press enter to try again" may appear. Follow directions in the display. If the fault
    reappears or does not clear, call an authorized servicer or the toll-free number in the
    display.
    If the same operation is attempted before having the wall oven repaired, the message
    "Feature not available" will appear. The feature will remain inoperable until service
    is obtained":
    Mar 15, 2011 | Jenn-Air 30 in. Pro-Style Electric Single...
    There is no heat coming from the microwave part of the oven, although the grill, convection oven, motor, light and fan all work. The 8 amp fuse on the board where the mains cable enters the oven has blown....
    Hello, If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven.the magnetron i guess is kind of faulty and this is the most expensive part in a microwave oven.
    If the display is on and the oven won't come on and run, there may be a problem in the door interlock system or the thermal protection system.
    wish yo good luck,
    take care.
    Jul 19, 2010 | Ovens
    F9 error code while using the convection baking function
    Jul 30, 2009 | GE Ovens
    Convection works but Microwave does not heat
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    duid
    May 26, 2009 | GE Monogram® ZMC1095BFBB /...
    Thermador CMT227N
    Hello air pro AC,
    Welcome
    You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
    Oh there are many things to check here.
    1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
    2.check that the wheels are not worn down.
    3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
    Do you get a error code?
    How old is it ?
    huuum
    Waiting your response!
    Oct 17, 2008 | Thermador Ovens
    My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
    like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
    Jan 07, 2008 | Ovens
    Ovens Logo
    273 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
