Question about HP Color LaserJet 2600n Printer
Printer HP Color Laserjet 2605dn printer is not giving the color prints correctly. The colors are very fade, only black color is fine, rest all color combination are very light.
  • HP Expert
  • 217 Answers
Your problem have only one solution - open laser/scaner Assembly carefully and clean all mirrors inside whit dry cloth. Dirty mirrors is the most frequently problem for 1600/2600 series
If you dont know how to do that just visit HP service
Posted on Mar 31, 2011
  • 3 Answers
Opening a HP2600/1600 Color Printer is not an easy job, if you are only user of this printer. You can damage it ..so if you are technically qualified engineer or have any experience of opeinng this type of printers, then only try it else contact HP Service Centre. If you ae residing in Delhi then contact Oldest Cartridge Refilling/ Printer Service Centre ..Asterisk Electronics Pvt. Ltd...(Tel) 011- 64596459
Posted on Jul 17, 2012
    Guru:
  • 433 Answers
Refill cartrige agian the color cartrige is empty
best regardes
if you see that is helpful plz don't forget to vote me
I want to mono print
I have the same printer and it needs to have all cartridges inside even if the color ones are empty and you need to select black and white in printer properties when printing
Oct 11, 2012 | HewlettPackard HP Color LaserJet 2605dn...
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Hp color laser jet 2605dn gives me a message printing document but does not continue print it then tels me to turn of printer and turn it back on
According to your problem, The instruction is correct.First remove all pending print job from print queue by double click on printer in printers and faxes wizard. Then reboot the printer and system both. After turn on give a print job. If it doesn't help you then check the page setup in printer properties.
Apr 28, 2011 | HP LaserJet 2605dn Printer
My Hp Color laserjet 2605 was not working some colors (yellow,megeanta) so how to resolve this problem ? all color tones are new ! i would pinted test page black and cyan was ok
This is a common problem with this model of printer. The scanner optic degeneration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta and yellow toner cartridges, red tones are the first to show fading. Colors shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a compliant technician to resolve this issue as it means dismantling your printer and cleaning the mirrors and lenses in the optic section to fix the problem.
Aug 09, 2010 | HP Color LaserJet 2600n Printer
Hp color laserjet black print fades to the bottom of the page.
dirty scanner.open the printer back cover.remove the scanner assembly clean it ,do the color calibration.u should be fine.
Amuna1
Jun 30, 2010 | HP Color LaserJet 2600n Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
May 15, 2008 | HP Color LaserJet 2600n Printer
2605dn prints red background randomly
n the Windows environment, the Automatic and Manual color options are on the Color tab in the printer driver. choose manual and click on grayscale
Jan 09, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
984 people viewed this question
Seeker5211
Seeker5211
