New HP Colour Cartridge installed into HP OfficeJet R45 only prints Light Blue? Any suggestions? Thanks for your help in advance.
  • Jacque Lamb Mar 31, 2011
    The cartridge is new and its an authentic HP Cartridge, any ideas?
Replace cartridge (use in original cartridge only)
Posted on Mar 31, 2011
    Hi, The cartridge is new and its an authentic HP Cartridge, anymore ideas?
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
HP R45 printer. fitted new colour cartridge but still olny prints in black
In the 'printer dialogue' window that comes up when you try to print, look under properties or preferences............ have you accidentally got the 'Print in greyscale' box ticked?
May 01, 2009 | HP OfficeJet R45 InkJet Printer
Non-HP ink cartridge
I refilled my new hp 60 cartridge at first it works out but after few print outs hp solution center detects that there is a cartridge problem? what should I do? purchasing a new cartridge is so expensive, thnx in advance......
May 07, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Can't print in colour
Hi Paddy,
It sounds like the color ink cartridge is clogged. You can try taking the color cartridge out, and take a paper towel and some windex with amonia. Spray the paper towel with the windex and then take the color cartridge, and wipe the bottom of the ink cartridge. After wiping the bottom of the cartridge, try pressing on the bottom of the cartridge (Print head) with the paper towel...You should start seeing some ink soaking into the paper towel. If you do not see any ink on the paper towel, then try wiping it again with the windex/paper towel. If after a couple tries, you can not get the ink to flow from the print head, then I would suggest getting a new cartridge.
The HP ink cartridges can get a bit tricky and the print heads will clog when the printer is left sitting for a long period of time.
Hope this helps.
Good luck.
If you have any other questions, feel free to post them.
IF I have helped answer your question, please remember to leave a feedback and or rating for my suggestion.
Mac =)
Feb 13, 2008 | Computers & Internet
Hp officejet 5610 how to select black ink printing only
Start, Printers and faxes, Right-click your printer - Properties, Printing preferences, Advanced, Print in grayscale - Black only...
Nov 05, 2007 | HP Officejet 5610 All-In-One InkJet...
HP k80 will not print yellow
spounds like a defective print head bud. these do wear out and most of the time it will cost as much as a new unit.. Good Luck
May 21, 2006 | HP OfficeJet K80 All-In-One InkJet Printer
52 people viewed this question
k24674
jasbo
jasbo
