Question about Frigidaire Washing Machines
My Frigidaire washer is displaying an E20 code and not completely draining. Is there something I can due before I spend unnecessary money calling a repairman?
    Brigadier General:
  • 6,277 Answers
Sorry, I do not have the list of decodes for your particular washer BUT (no promises!) I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside. It's also a good habit to check the filter regularly anyway!
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 31, 2011
How do you fix e20 code
Hello John, thanks for your inquiry!
From my understanding your Frigidaire front load washer is displaying an error code of "E20" and you would like to know how to fix it. An "E20" code stands for water is not pumping out fast enough this could be a problem with your drain hose, pump, or control panel. I would suggest checking the drain line to make sure it is not restricted. If the line looks clear it could be a problem with your drain pump or control panel. I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Apr 23, 2015 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire gallery series keeps saying E20 and the clothes are still very wet at end of cycle. What can I do to fix this problem?
Thank you for your inquiry, B.paddock!
From what you have described your Frigidaire washer is displaying an "E20" code and once the cycle is completed the clothes are still wet. Typically, an "E20" code stands for the water is not pumping out fast enough. You should check your drain hose to make sure they are not restricted or clogged. If your hose is fine it could be a possible issue with your main control board or drain pump. I would then suggest contacting a professional technician for proper disassembly of your washer and replacement of the electrical components. If you do not have a professional connection you can visit your manufacturer's website to locate a technician in your surrounding area. I hope this information is helpful. -Matt
Feb 23, 2015 | Frigidaire Washing Machines
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Aug 21, 2011 | Frigidaire Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Code e20
Check filter for blockages and waste hose outlet.check pump impeller in case something is jammed in it.you will need to remove it.if impeller moves freely it may need a new drain pump.
Hope this helps.
Aug 03, 2009 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front loader washer will not fully drain water and leave clothes soak and display an E20 code
An e20 error is a slow drain. Basically you have a clogged pump. I just had to unclog one today! Unfortunately they are a little hard to get at. Usually they have a small sock or coin stuck in them. The pump is located in the right back. Good news, no cost to fix, bad it's just going to take some time.
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
