Question about Ovens
I have a Blanco BOSE 166X oven, bought in 2008 but only installed a few months ago. The timer was always difficult to set, and now I can't set the timer at all and the oven will not come on. I have taken the top cover off the oven and there is a relay that's part of the clock assembly that cuts out all the time. My guess is I will have to get a new timer assembly, but would rather not if I can help it. Any ideas?
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
SOURCE: How to set Clock?!
To set the time of day. Press the cook time button and the ready time button simultaneously (2nd and 3rd from left). Use the plus and minus buttons to set the required time.
Posted on Jun 05, 2008
SOURCE: Main Oven Issue??
Thank you so much! Holding the two (autocook on and off) buttons together got rid of the A and now the bottom oven works! Great!
Posted on Sep 15, 2008
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 547 Answers
SOURCE: oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Posted on Aug 04, 2009
I have a whirlpool oven which I bought from Ikea a few years ago but at the end of a timed programme the beeper is not going off can you tell me the answer please.
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
Feb 26, 2015 | Whirlpool RBS305PDS Electric Single Oven
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
I AM GETTING GAS TO MY STOVE TOP,BUT NOT MY OVEN. I HAVE A CROSLEY OVEN. I MOVED IT ABOUT A MONTH OR SO AGO TO INSTALL A FLOOR. ANY IDEAS?
yes, check your timer or clock if the clock is set on automatic it will not work, needs to be on manuel. or it may need the oven ignitor, its berry sensitive its the part nest to the oven burner on the back.
Jul 12, 2011 | Amana Ovens
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
Jenn air wall oven control panel not working properly
You will need to replace the front control board and the touch panel
Mar 28, 2017 | Ovens
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Ovens Logo
201 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
