Question about Car Audio & Video
I have a JBL 86280-0w420 and I wanted to know thewireing color code schematics
3 Suggested Answers
  • 1121 Answers
SOURCE: Internal wiring schematic for a JBL 4311 WX-A
the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
Posted on Feb 18, 2010
SOURCE: jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Posted on Nov 09, 2010
I need to know the color code or the resistor's value for r134 on the Creature's pcb. If anybody knows, please respond.
Hi I done a search on Google and found a schematic it might help. Type in. Harman kardon jbl creature schematic photo :::: I done this search on my phone ...good luck
Jul 13, 2016 | Harmon Kardon Jbl Creature 3-piece Powered...
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
Picked up and used JBL GTS 300 and wanted to install it in my truck. I'm looking for a simple wiring diagram. I'm pretty good at hooking things up but it would be nice to have a guide. JBL is a...
You want to pick up a wiring harness for your truck at your local parts store or online, should be petty cheap. Then all you have to do is match up colors, ie purple with white stripe to purple with white stripe. The other thing you can do is hook a9 volt battery between the similar colored wire pairs from your trucks wiring. Then you will know which pairs go to which speaker. The other ones you need to know about are red, black and yellow, they should correspond directly to your trucks wires, red and black are power and yellow is the accessory
Jun 08, 2011 | JBL Car Audio & Video
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
Feb 16, 2010 | Audio Players & Recorders
I installed a sony x plode amp in a 2005 corolla which had a stock six speaker amp by jbl which came with car i also bought a jensen hd dvd radio i installed radio but need a wiring schematic to by pass...
If I am going to have a car and do a lot of audio installations, I try and order the manual for it. The manual usually has a full wiring schematic. You might call down to your local Toyota dealership and see if they can help you with the wiring schematic.
Also, you could just run new speaker wires. I know its a pain, but that is another alternative. With that being a newer car though I can understand not wanting to start tearing off internal moldings.
Aug 04, 2009 | JBL SCS145.5 System
Bloon Fuses!
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
Aug 18, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
