I had the balast taken out of the Toshiba TV # 62HM15A. Reason being, there was no picture -- just black screen, after power on, green light appears then green light blinks then it makes cliclk and clack noise then it automatically turns off. It starts itself and go thru same sequence of events. The Balsat p/n 23122497 sn 057064358. The question is how to test it ? I alrady replace the bulb but no avails.. I am supposed to send the lamp back and get it replaced -- before i do that -- i want to make sure the balast is ok before proceeding . Where can i get new balast and reasonable price. Thanks
    Novelist:
  • 159 Answers
Hi, the word ballast is rather a misnomer in flat screen tv's, reason being flat screens have what are called cold cathode fluorescent lights in them, and there are usually more than one-it has been my experience that the power supplies that drive " ballast's " are what can go soft-and sometimes the power supply has the ballast right on the same board, you can try reducing the brightness to keep set from resetting-that'll tell you if power supply if " soft " on not. also-i have used a different piece of equipments " ballast " to power another-i once used a H.P. pocket pc to power flat screens bulb temporarily for just the same reason, to determine if bulb or ballast was in err. New " ballasts by the way run around 150 if i'm not mistaken they aren't cheap unfortunately. Hope this helps, PRODZILLA
Posted on Mar 31, 2011
Green "snow" on and off in the picture on my 62hm15a Toshiba TV.
it must be a hardware problem sir. try to check your manual and see the troubleshooting.
CHARCOIS
Sep 13, 2008 | Toshiba Televison & Video
Toshiba 55 55S41U Black screen no back light no picture green power light
have you checked for dry joints or blown capacitors , with a power surge depending what kind voltage or amperage the circuit received it might have even blown screen connect it will certainly fry a lot of components ,have you looked for holes in capacitors ,resistors or burnt tracks between components . that's about all I can think of to check also some power panels have built in fuses to stop surges if you could obtain a circuit diagram that should help you also you could google your query and see if you get any assistance it costs nothing and you could get your TV up and running again . All the best .
Dec 19, 2015 | Toshiba Televison & Video
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
TOSHIBA 62HM15A
Have you changed the lamp? Check and see if it is shattered or discolored.
Aug 20, 2009 | Televison & Video
Power indicator only blinks green for several minutes, then...
I had identical problem which continued for months before the screen started to get dim then went completely black with only the audio remaining. This will happen when the lamp and or balast board starts to fail. You can buy replacement lamp off the internet and install it using only a screw driver. Your Sony manual provides instructions. Don't buy any of those cheap off brand lamps; light output might be low.
Dec 03, 2008 | Sony KDS-R50XBR1 50" HDTV
Toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Sep 30, 2008 | Toshiba 62HM15 62" Television
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
366 people viewed this question
Top Televison & Video Experts
