Question about Mitsubishi VS-60707 60" Rear Projection Television
Mitsubishi VS-60707 60 in code 24
Hi Slinte,
In searching for solution to my Mitsubishi vs-60607 code 24 error problem, I come across your posts here which i find very helpful. By following your advices, I replaced ic451. However, the problem is still the same. The voltages indicated in the power supply circuitry block diagrams are kind a off. 5.2 V at D970, 25.4 V at R974, 12 V at D974, 9.9 V at D972, no voltage at pin 1 of IC952, no voltage at pin 3 of IC935. Base on your expertise, do you think the transformer T951 is at fault? Or I 'm looking at a wrong componet. Please help. Thanks.
Ben
Htb_97@yahoo.com
  • htb_97 Aug 07, 2008
    I have no luck in finding the replacement part for T951. Do you know any online source that i can use to order my parts.
    Thanks
  • Mitsubishi Master
  • 8,617 Answers
Because of the various voltages that are affected I would say replace T951 thats the most likely component.
Posted on Aug 05, 2008
  • Sonny Berry
    Sonny Berry Aug 07, 2008
    The part number is 350P34020 and the generic number is ZTS5137A power transformer. Unfortunately they are both no longer available. You may be better of trying to locate a replacment board.
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 tv
can you tell us about the problem you are faceing?
Aug 05, 2008 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
My mitsubishi vs 60607 big screen will not come on...green timer light comes on then off....tried holding down menu and input buttons and the code it gives me is 2 flashes and then 4 flashes...what does...
The 2,4 error code means a problem in the Vertical circuit.
This could (due to the age of the set) be bad solder connections at the vertical output chip or a part bad anywhere in the circuit.
Problem is in Vertical circuit.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 16, 2010 | Mitsubishi VS-60607 TV
Mitsubishi vs 60607 circuit board
this isn't a notorious problem. many problems can cause this. the instant on/off behavior just says there is one of many fuses blown in the television. you can't just replace the fuse, when it fails get a failure code find out what it means and repair the problem. I would recommend paying someone to do it if you don't want to trash your mits set.
to get the code you hold down the menu and input button for 5 seconds after the on/off sequence. it is a 2 digit code with a pause inbetween, example 2 pause 2 pause 2 pause etc. is a 2.2 code
Jan 23, 2009 | Mitsubishi VS-60607 TV
Does the VS-60607 have a digital tuner
No it does not. Only mitsubishis with a digital tuner are the ones that have a DM inside.
Dec 12, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
Mitsubishi vs-60607 tv parts
go to this link and leave them a email with your model number and what part you need. They should have what youre looking for.
http://servicemanuals.vstore.ca/
Aug 07, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Here are the two top reasons that can cause the 60607 to throw a 23 or 24 code. Check these items then let me know what you find.
1. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Mitsubishi VS-60707 60" Rear Projection Television Logo
234 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
