Question about Samsung LN32A330 32 in. LCD TV
My Samsung LN32B530 won't turn on but the power light is on and responding. The screen and blank. Checked the capacitors and no bulges or leak. if you could comment on how to solve this... thank you
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 31, 2011
  • Samsung Master
  • 8,457 Answers
The tv Tuner signal board is dying and it not taking in the tranmitting tv signal from the incomming broadcasting tv stantions signals.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Samsung DLP HLR5067w won't turn on
Check power supply and replace any bulging electrolytic capacitors. It is common.
Feb 02, 2013 | Televison & Video
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
I Do have a Samsung LN32B530 model and it won't turn on the power lights are on but there is no picture and audio. I checked the capacitors and they are all ok no bloats and leaks... what would be the...
TV won't turn on not always from leak capacitors, T-con or pcb main it self can cause it.
Unplug T-con board than turn it on, if still no picture replace main board.
If not sure to replace pcb main, i suggest you to call samsung technician.
good luck.
Mar 31, 2011 | Samsung LN32A330 32 in. LCD TV
740N blank screen
I would inspect all the caps, if you find even one bulging top/leak you should replace them as a set.
See failed SAMSUNG here, use good caps, such as PANASONIC FM or FC series from DIGIKEY.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG megnev2 =% 20 & 740N = & Category = & kat2 schematics
May 02, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung 906BW monitor wont turn on, power switch
rommelnmariv, 906BW will need to use warranty or if you are not a tech with soldering equiptment then unit will need to visit a tech to be evaluated for it's Black screen or It's Blank n Black screen problem. Read my older fixya responses (late 2009) and follow all links. Yes, some of these can be fixed-up (DIY) for under $10. Read my fixya profile for about an hour !!! Maybe you will ask your 906BW " What Brand of capacitors do you have inside you??" Bye for now. 12fixlouie
Mar 27, 2010 | Samsung 906BW LCD Monitor
Blank Screen
Any bulged capacitor is a failed capacitor. The nice-looking ones next to the bulged ones have failed too since they are in the same circuit.
The real fix is to replace ALL the Electrolytic capacitors. You can use ones with slightly higher voltage ratings without problems provided that they will fit.You can use two 470's to replace a 1000 provided you can fit them in.
There may also be a 47mf/25 volt cap off to itself. Replace it too, if it fails, the unit will just not come on at all.
Dec 21, 2009 | IBM ThinkVision L170 17" LCD Monitor
I have 40? LCD Samsung flat screen TV model: LE40A557. This is 16 months old. Today the screen went blank and power indicator light blinks. I have switched the TV off and removed all equipments attached. I...
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
Oct 17, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LN32A330 32 in. LCD TV Logo
287 people viewed this question
Henry  Thomas
Henry Thomas
