Question about Car Audio & Video
I had a car wreck and I put my truck in the shop to be repaired. I work 2 nd shift so after two weeks of them having my truck my wife picked it opals said shed not notice the radio said protect on the face. I tried the code I thought it was but it just will not take it.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try pressing the resest switch, if that doesn't work, check all of your speakers and speaker wires for shorts, grounds and/or bare spots. if you find any, remove them and press reset again.
Posted on Mar 31, 2011
I have a 98 Chevy Malibu My car was hit on the driver side weeks later the headlight stopped working I replaced the whole headlight nd bulbs The auto low or high beams work but only in one head light
You may need to change the wiring harness.
2000 malibu headlight problem - Tech Support Forum
www.techsupportforum.com > ... > Automotive Support
Dec 14, 2008 - 8 posts - ‎2 authors
I have a 2000 chevy malibu with headlight problems. ... High beams work correctly.... I suspect a ground problem but cannot locate the ground cluster. ... Grouped together there, one pink wire to the Headlamp Switch, and one to ... my Wife's car has lowbeam on the left side that just won't work and now the ...
Dec 20, 2015 | Cars & Trucks
Why won't my transmission shift on my 1999 Mercury Sable?
1.) you never check your transmission fluid and it is low. Check it and fill according to instructions in your car's owner's manual. Check your oil, while you're at it. Get your dad, boyfriend, husband, or female companion to teach you how to check your car's oil, transmission fluid, coolant, brake fluid, and any other hydraulic cylinder fluid. All adults should know how to do this.
IF YOU DO NOT LEARN TO DO THESE THINGS, YOU CAN COUNT ON VERY EXPENSIVE CAR REPAIRS. Repair shops will love you. I have a foolish brother who wrecks his automobiles' engines repeatedly because he says "I shouldn't have to do this stuff".
2.) there is a broken linkage cable or rod.
3.) a bad electrical connection.
4.) you trashed the transmission by putting it in gear while rolling in opposite direction of desired travel
It is likely you will need help with this. It is likely you will need a repair shop. Get help from friends and family, BEFORE going to a repair shop. Look for an online ratings service such as Angie's list or Yahoo yellow pages to make sure you don't go to a rip-off joint.
Good luck Kimberly!
Aug 29, 2015 | Mercury Cars & Trucks
Gear shift solenoid or transmission problem?
You needed not pay $4000 for any transaxle,you got taken big time
They cost about $2500 tops to rebuild
The shop never diagnosed the original issue,new trans needed or not
Dec 03, 2012 | 2000 Honda Prelude
Code PO 740 ,high shift from 1st at first ,then had to let off the throttle to shift to second ,then won't shift out of 1st shows only code PO 740
It is possible that the synchronizer from 1/st to 2/nd gears is finished, this is not a repair that you could do by yourself as it may require the special tools and the setting of a shop to work underneer of the vehicle.
If you take your car to a transmissions workshop, they will test it with a computer and determine what the cause is of this behaviour may be. If it is a matter of synchronizers, it will be very wise to exchage all of them, once the tranmission is dismantelled.
That work, may take three to four days to be repaired. The more time you take to fix this problem, the worst the failure will become.
Good Luck...!
Apr 12, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
S light blinks on dashboard and the car do not move well
Could be your VSS Vehicle Speed Sensor. Since your car is a 1996 model it is OBD2 (On Board Diagnostics 2) This means you can go to AutoZone and have it scanned for free.
Feb 12, 2010 | 1996 Honda Accord
My 2000 Buick LeSabre whines and will not shift into any forward gears. It also has a very loud whining noise. Car starts fine and I am able to put the car in to reverse. Once I put the car in Drive it...
it does sound like the transmission has packed it in. you might be able to find a decent used one via a wrecking yard and get a local mechanic to install it.
try to find one out of a car with under 100K miles on it.
Oct 04, 2009 | 2000 Buick LeSabre
WRECKED 2006 CHEVY HHR
talk to your insurance company, hopefully they will make an adjustment for the extra repairs. i hate to sound like a commercial but, geico helped me out when that happened to me, when my daughter wrecked my truck.
Feb 26, 2009 | 2006 Chevrolet HHR
My driver and passenger seatbelts wont retract.
return it to the shop. they are obligated to correct that safety issue.
Jan 03, 2009 | 2002 Dodge Stratus
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
