Question about Nokia N73 Cellular Phone
Hi my N73 nokia mobile display shows headset is connected with connecting any cable, so when i received a call i am not able to hear anything..
Switch off ur mobile n again switch on
Posted on Apr 04, 2011
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
My NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't...
Hi
The audio(headset) jack should be replaced ,that may be damaged due to slight liquid intrusion.
So take it to an authorized service center and get it replaced.
Dec 20, 2017 | Nokia N73 Cellular Phone
My nokia n 73 phone is howing enhancement symbol on the right corner of the screen even if no enhancement is connected and when i make or receive calls, i am not able to hear the other persons voice and...
try to clean the headset interface at the bottom,might the socket is corruded and lead inoto shortage...
if that symbol never removes.you can never hear incoming calls or even the person calling might not here you...
if doesn't work,bring it to a mobile srvice shop near you. might a hardware (board) problem.
hope it helps....
Jun 04, 2011 | Nokia N73 Cellular Phone
The headset symbol is showing on my screen on my N97 and I dont have a headset connected at all, when people ring me they can hear me but I cant hear them because apparently my phone thinks there is a...
The headset jack is jammed.
Try blowing some compressed air in there and also insert a headset plug and wiggle it about to see if it knocks the stuck bit loose.
Mar 05, 2011 | Nokia N73 Cellular Phone
Sir I buy bh-105 bluetooth for N73 But can not connect.
Please follow the below steps to connect your head set to mobile.
1. Ensure that your mobile device is switched on and the headset is off.
2. Press and hold the power key of headset for about 5 seconds until the green indicator light starts to flash quickly.
3.Activate Bluetooth connectivity on your mobile , and set it to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. If necessary, enter the passcode 0000 to pair and connect the
headset to your device.
When the headset is connected to your device and is ready for use, the green indicator light flashes about every 5 seconds.
Thank you
Aug 07, 2010 | Nokia N73 Cellular Phone
MY MOBILE IS NOT CONNECTING TO P C ALLTHO PC
its not only pc suite that needs to be installed. You also need to install nokia connectivity driver. This willl install your usb cable.
You can download the connectivity driver from the nokia link below.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-6102i/pc-software/cable-drivers
Also cross-check if your usb cable is well connected to your phone and computer.
Take care.
Apr 22, 2010 | Nokia N73 Cellular Phone
I updated n73 mobile it is not working
hi, i had this problemonce with the n95, i tried re installing the software, it took about 3 attempts but it did work
Jan 02, 2009 | Nokia N73 Cellular Phone
HS-23 Nokia Headset
hey kev.. all i can ask you is ... the following 1) open the ear piece of the non working .. then take a multimeter (keep meter in resistance mode) and check the resitance if its good it will show you.. apx 32 0hm and if its showing you 0 or .1 or below 16 ohms.. 2) after you disconnect the speaker.. the broken one that is... chek the cable connectivity.. or rather continuity.. for this keep the meter in continuity mode the pervious resistance mode.. then take one wire and connect one prob from meter to it.. and take the other prob and connect ti too the pins of the cnnector.. ( here is there are 4 pins dedicated to the ear phone.. 2 for each.. nd they are towards the end sid.. just below the # key.. frm # key the last 4 pins connectors are for audio.. ) check the.. pins on the cord connector not the phone.. i hope you can find what wrong with your... head set now.. and yeah if the speaker is out jsut replace both the ear piece with sony or aiwa earphones.. it wil work best if your cable is gone then all the best buy a new one tc aditya
Aug 04, 2007 | Nokia HS-23 Headset
Nokia N73 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
