Question about LG Washing Machines
Alignment of v belt in washing machine - LG Washing Machines
  • LG Master
  • 17,129 Answers
The belt do not need any alignment as the pulley's must be in-line and all you need to check for is that there is no shift on the motor mountings or the main pulley so that the belt is off line.
If not having the same type and size of the belt is most important.
Posted on Mar 31, 2011
I just replaced belt on maytag Neptune but it keeps coming off. Any suggestions?
Hello Mathew, I only have a guess. I would make sure the pulleys that the belt runs on are aligned with each other. If a pulley becomes out of alignment , it could make the belt ride out of the groove and derail. Also check to see if the belt tensioner is working properly. A loose belt can slip off the pulley.
Aug 01, 2014 | Washing Machines
Drive belt comes off every off so often
Please check and see the alignment of the pulley and belt, Check for friction of the drive shaft which can cause the belt to slip over.
Click this link: belt replacement.
Jan 23, 2013 | Ariston Technologies AL128D Margherita...
The belt on my hotpoint aquarious wma33 keeps coming off
Belt is not adjusted tight enough when being fitted, if no adjustment can be made by moving the motor then the belt may be stretched and will need replacing, the drum bearings may be faulty and causing the pulley to be out of alignment, water may be getting on to belt causing it to slip off.
Dec 29, 2012 | Hotpoint Washing Machines
Why does my belt keep coming off
It might not be on tight enough, adjust tension if you can. There should be a slight ping in the belt but still be able to give it a slight twist.
If you can't adjust, motor does'nt allow adjustment, your belt may be stretched and need replacing.
Or something may be causing alignment issues. Worn bearings can cause a pulley to be out of alignment and allow the belt to slip off.
Dec 28, 2012 | Zanussi Washing Machines
The belt that drives the drum on my washing machine keeps slipping off, It is a brand new belt so have no reason to believe it has worn. When we put it back on it is so difficult to do, but as soon as it...
Check the alignment of the pulleys, If they are not perfectly aligned the belt will be thrown off at high speed. Also check that the axles are parallel to each other because if a pulley rides higher on one side the belt will ride towards the higher point and be thrown off the pulley.
Mar 12, 2011 | Creda W100FW Front Load Washer
Maytag Neptue frontloading washing machine model MAH5500BWW stopped spinning (machine is about 15 years old). I opened up the back and saw the drive belt was thrown. Reinstalled it (perhaps badly) and...
i would say you have a warped main pulley, run the machine in spin,watch it early to detect any wobling in the belt should be no sideway movement. also check main pulley is tight with no lateral wobling.
Dec 21, 2010 | Washing Machines
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
My new front loading washer is not spining. It is 3 months old. We have a 12 month warranty and labor
call whirlpool customer service, they own maytag now, you will be covered under warranty.
Mar 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
