Question about Briggs & Stratton Garden
My mower engine was fine last time it was used. This time it is running poorly and very rich. Using excessive fuel. Only runs correctly when fuel is running out. The air cleaner is clear, the governor is working correctly and I replaced the spark plug but no improvement.
  • Tony Woodruff Apr 03, 2011
    Thanks for the advice, Kiltnar - I should have said it is a Briggs & Stratton 35 classic engine - no fuel bowl, no float to stick. I couldn't get the carby off without undoing 3 head bolts to remove a major bracket, so I took it to the local mower shop! (Against my principles, but sometimes you have to compromise!) - Woody17
    Novelist:
  • 111 Answers
The carburetor has a problem. You can take off the carburetor with a 5/16 socket and a 3/8 socket. Take off the air cleaner cover and remove the air filter. Then remove the air cleaner housing. This is three bolts that can be removed with the 5/16 socket. Take care not to damage the gasket that is behind this. Then the fuel line needs to be crimped. You can do this with lockjaw pliers. Then use a set of regular pliers and take the fuel line off. After this the carburetor has two more bolts that holds it on. They can be taken off with the 3/8 socket. The fuel bowl nut can be taken off with a 1/2 in socket. I would take it off and see if there is anything inside of the fuel bowl after removing it from the engine. If you see a round piece of metal in the fuel bowl then it has dropped a welch plug and the carburetor will need to be replaced.
Posted on Apr 03, 2011
  • Kiltnar Apr 05, 2011
    That carburetor hardly gives any problems by itself. It is usually the gasket and diaphragm that sit underneath the carburetor. For that fix you would need a Briggs and Stratton part number 795083. It has 6 phillips head screws that hold the carburetor onto the fuel tank. You can remove the carburetor from the engine by using either a 7/16 in or 3/8 in socket on the front of the engine, and a 1/2 in socket for underneath the carb body. Then swing the carb down and unhook the linkage that controls the throttle. Then you can remove the carb from the fuel tank. It is one of the most dependable engines that is out there.
    I'm sure the local repair shop appreciates the business. I had one at my work that would not work correctly until I took it completely apart and soaked it in carb dip. That one was a toughie.
    I hope everything comes out like it was new. :)
    You might print off this one and keep it somewhere where you can look at it again. With the mystery fuel that we have now, the diaphragms are not holding up like they used to. So it may have to be done again in a year or two.
  • Tony Woodruff Apr 05, 2011
    Thanks again, Kiltnar - I will keep your comments for future reference!
    Woody17
Mower running on full choke?
I installed a fuel shut-off. To solve my problem.
Apr 09, 2014 | Mtd Garden
2006 pacifica
Car may be running rich. If the car is getting normal mpg, I would not worry. The codes that indicate poor converter efficiency indicate the converter is wearing out. If that code keeps coming back, replace the converter. If it is getting poor mpg, I would look for something causing rich operation. Possibly a broken fuel pressure regulator or maybe a bad map sensor. Continued rich operation will cause the converter to fail prematurely.
Jul 14, 2017 | 2006 Chrysler Pacifica Touring
Black smoke and bad fuel consumption what is the problem? Oh it an 07is volvo s40 20d
Hi there:Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor.
How did the fuel get into the cylinder in the first place? Some of the causes of excess fuel are a carburetor that is out of adjustment, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or computer sensor. If black smoke is present, check the engine oil as in the white smoke example to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil. Call your mechanic and advise him of what you have found.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2007 Volvo S40 2.4i Sedan
I have a 92 blazer 4.3 vortec
Hi there:
Thank you for using FixYa, have a nice day.
Mar 04, 2012 | Cars & Trucks
Hi there:
Black smoke>fuel consumption>rough idle
Hi there:
My camry 2001 v6 engine emits black smoke and **** in traffic
Black smoke indicates running "rich" (using excessive fuel) sounds like an injector is sticking open. I would first run a strong fuel system cleaner through it. (Maybe even have a professional fuel system cleaning) Ques? When was last tune up? A dirty air filter would contribute, but not make alot of black smoke.
Mar 26, 2011 | 2001 Toyota Camry
98 gm blazer has black soot from muffler giving code insufficiant switching o2 sensor bank 1 and 2 any ideas ?
Your Jimmy is running rich, air fuel ratio is not correct. Start with cleaning your MAF sensor, a dirty MAF sensor will cause your engine to run rich or lean, other causes would be a faulty fuel pressure regulator. Start with the simple and to common and try cleaning your MAF sensor, you can pick up a can of MAF sensor cleaner at most auto parts store like Auto Zone or Part Source.
Also make sure your engine is running at the proper operation temperature 190", cold running engine will cause the ECM to run your engine rich. Causing the back soot and fouling up your spark plugs and intake ports with carbon.
The ECM was programed to recognize the 4.3 vortec to run at 190" and anything cooler will cause it to run rich and poor on economy.
Thank you for using fixya and good luck.
Apr 27, 2010 | 1998 GMC Jimmy
Garden Logo
195 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
