Question about Avid Shorty 6 Cantilever Brakes Front
Squeaking - Avid Shorty 6 Cantilever Brakes Front
    Brigadier General:
  • 8,546 Answers
Holden VT 2000 5.7 has a rattle in top of motor and squeaks loud I think it is a lifter but should it squeak like that
SQUEAKS: Oh heavens NO...!!
(SORRY... Sorry...(My bad))... err... err.
WRONG...!!!
SQUEAKs ... So NOT start it again...
More important: Do NOT OVERFILL the OIL.
SQUEAKs - - "Have it towed IMMEDIATELY"... No!!
SQUEAKs -- Not even on my home planet.
If you have any oil at all... then your oil pump is kaput... you are toying with a major disaster... if this isn't a total spoof...!!
Indeed. Squeaks! -- Seriously? Squeaks?
Jan 22, 2016 | Holden Cars & Trucks
97 Buick Park Ave. Non-Ultra. Mileage 200K. Was squeaking at morning cold start for about 5 to 10 min. Replaced Serpentine Belt, belt tensioner, alternator, and PCV Valve. STILL squeaking at cold start....
How's your engine coolant level? If you've got a water pump leaking coolant, your belt will squeak, as the pump will leak the coolant directly onto the belt. You'll see the spray pattern under the hood if it's been going on for a while.
Oct 18, 2013 | 1997 Buick Park Avenue
Squeak squeak squeak all the time
a/c pump and check power steering check front brakes discs for stones and front wheel bearings .
Sep 12, 2012 | 2006 Pontiac Grand Prix
Panasonic PT-47WX33G doesn't start up (no picture no sound). Power indicator blinks 5 times while I hear a repeating squeaking sound inside the TV (squeak squeak squeak squeak squeak). I replace...
If your set is blinking 5 times it is the HV power supply.
You most likely have a sorted Horizontal Output Trasistor. (HOT)
If you have any further questions please respond to this post.
Thanks
asnowman
Jan 22, 2011 | Panasonic Televison & Video
Squeaking sound from shock absorbers
ball joints won't squeak like that; they make a popping noise when they're bad. it is very common for shocks to get water in them and start squeaking, and it's usually a horrible screeching squeak. The only way to get rid of the squeak is to change out the shocks. Hope this helped.
Nov 28, 2009 | 1997 Ford Expedition
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Squeaky Printer
Mine had a similar squeak and I took the toner out and shook it. Squeak went away.
May 29, 2008 | HP LaserJet 1100 Printer
Avid Shorty 6 Cantilever Brakes Front Logo
107 people viewed this question
Top Avid Cycling Experts
Michial Gueffroy
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you an Avid Cycling Expert? Answer questions, earn points and help others
