Question about Brother MFC 240C All-In-One InkJet Printer
When i print it comes out blurry - Brother MFC 240C All-In-One InkJet Printer
  • Brother Master
  • 379 Answers
Could be your print head has gone out of alignment.
This is only a problem if you do bi-directional printing - speeds up printing but even when working correctly does degrade print quality a bit.
Do a print alighment test (see your user manual - available on the Brother website) and follow the instructions on the test sheet it will produce.
If this doesn't help, try disabling bi-directional printing. This will vary according to which operating system you have, but for example in Windows XP:
1. Go to Control Panel 2. Double click "Printers and Faxes" 3. Right click the appropriate icon for your Brother printer 4. Click on "Advanced" tab 5. Click on "Printing Defaults" button 6. Click on the "Settings" button 7. Un-check the "Bi -Directional Printing" box 8. "OK" to close all windows.
If neither helps, this most likely means your print head has been damaged. I'm afraid there is no simple solution to this problem. Repairing these machines isn't straight forward and parts are very difficult to obtain and very, very expensive, so much so that 99 times out of a 100, it isn't cost effective to repair. You could approach a Brother service agent, but it's highly probably that they will charge you more than buying an equivalent brand new machine.
Posted on Apr 02, 2011
The printing is blurry. How can I fix it?
I would start by cleaning under the print head. You could have some dust that's causing the blurring.
You can also run a "cleaning cycle" and a "head alignment" which may help.
Mar 01, 2016 | Canon Pixma MX410 All-In-One Printer
How do I fix blurry print
Blurry prints can come from a couple of things. However with most issues relating to blurry prints on laser prints the following needs to be checked.
1) Is the paper damp - Try opening a new ream of paper and try printing to clear it.
2) Is the toner unit incorrectly installed or remanufactured with incorrect toner - Try replacing the toner cartridge.
3) Is the drum past it\'s use - If your machine has been reading drum near end or replace drum then it has reached or reaching maximum page count for the drum. Replace the Drum unit.
4) Are the reflecting mirrors dirty - Check inside the machine when you have the toner and drum unit out and see if you can see a narrow indentation above where the drum sits in the machine(Normally about 15cm long by about 8mm wide with rounded ends). Carefully clean this indentation with a lint free cloth.
Sep 05, 2014 | Brother HL5470DW - HL-5470DW Wireless...
Color mismatch and blurry/smudgy prints
Remove ink catridges and clean print head, shake inks and reinstall the inks, if problem persist, Uninstall the driver and reinstall. thats should help. Some time if the print head are dirty it prints multi color. You have to make sure the Head is Clean and install th inks properly.
Dec 10, 2012 | Epson Stylus Photo R1900 InkJet Printer
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Blurry printing on laser printer
You have a bad drum. Return the drum for a replacement and you should be good to go.
Armymason
Apr 01, 2009 | Brother HL 5250DN Laser Printer
HP 4200 printing very light, smudgy and blurry
Remove the rear door by pulling it down and squeezing the left tab to remove it.
Press the blue hooks and remove the fuser. Look for a worn coating on the gray roller.
Feb 19, 2009 | HP LaserJet 4200 Printer
Trying to set up a Lexmark 1185 with Vista. I've downloaded the driver and have followed the instructions on the guide pages, but my printing still comes out with blurry picture and words that are...
U get blurry picture and words that are printing double.this is not problem with u r Installation .it is due to print cartridge please check printer with ok cartridges ,it should be working ....
if this information is useful for u please Rate me.............
Jun 15, 2008 | Office Equipment & Supplies
Brother MFC 240C All-In-One InkJet Printer Logo
144 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
