Question about Canon imageRUNNER 3300 All-In-One Laser Printer
I connected the Canon iR 3300 using Ethernet cable to the LAN switch 'D-Link DES-1005A' for the printer and scanning purposes in my office.In the same Switch i having a port connection of my internet using Ethernet cable coming from my broadband modem. And the LAN switch is connected to my single LAN port PC using network cable/Ethernet cable. But the problem is i can't use internet and printer at a time means if the IP automatically detected for my internet it works only for internet,not getting priter working!. if i changes the IP address in LAN settings then the printer works but no Internet connection. How i can get connected these two options simultaneously in my computer using the LAN switch. please reply me back with the remedy for this issue. thanks.
  • 47 Answers
SOURCE: Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
Posted on May 30, 2008
spinal
  • 287 Answers
SOURCE: Canon iR C3220 Printer TCP/IP settings
Wow,
I am not sure why or how I just bumped into this question 8 months later....and why no one has answered your question prior. I hope to God some one has helped you or you bumped into it on your own. If not, press additional functions,system settings, network settings, and the rest is obvious.
Posted on Jul 15, 2008
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
  • 117 Answers
SOURCE: HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
Posted on May 06, 2009
SOURCE: Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Posted on May 19, 2009
How to setup my des 1008d in my computer
The DES 1008D is an unmanaged switch. therefore there is nothing to set up. Just plug it in and connect to your computer via a cat 5 cable. Here are the manuals
Link DES 1008D
May 06, 2014 | D-Link DES-1008D 8-Port Ethernet Switch...
Download Driver D-link DES-1005A
yesi need a driver setup disk i lost one
Feb 09, 2012 | D-Link DES 1005 Ethernet Switch
How to connecte d-link switch model-DES-1008D two same switch pls urgent
Sometimes we need to connect 2 switches, which can be done by using Ethernet Cable (CAT5 or 6). Just connect the cable to the LAN ports from one switch to another. Let me know the purpose of doing so that i may guide you better.
Hope this helps!
CreativeTECH
Nov 16, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Getting low or no connectivity error when trying to connect laptop and other devices to 5-port DLINK switch. Lan line going to switch is confirmed working as i'm able to plug the laptop and other devices...
please change the cable which is connecting your laptop to D-Link DES 1005 Ethernet Switch.
This error appears when you have either a bad cable or bad switch or NIC card on Laptop.
As you have Laptop and other devices and getting the same error , so i suspect issue with the cable.
Please use a new Straight LAN cable.
Oct 31, 2010 | D-Link DES 1005 Ethernet Switch
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
How to link with 16 port switch with 8 port switch
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
Apr 03, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I have some problem with my D-link Des-1008D switch.I used it to connect 2 computer in my home and one cable form Internet shop.At that time, that Internet shop used manual IP to connect PC.And then That...
Does your ISP supply _one_ or _two_ IP-addresses per account?
On each computer:
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
What "IP-address" and "gateway" do you get for each computer?
No, a "driver" for the switch is not necessary, and will not help.
Instead, buy a "router" (with or without wireless capability), and rewire your network:
Cable-modem -> Ethernet-cable -> WAN-port on router
LAN-port-#1 on router -> Ethernet-cable -> Computer #1
LAN-port-#2 on router -> Ethernet-cable -> Computer #2
Turn the cable-modem off.
Turn the cable-modem on.
Turn the router on, to get one IP-address from your ISP.
Restart each computer, to get new IP-addresses for each computer.
Within the web-browser on each computer, disable "auto detect proxy".
Nov 16, 2009 | D-Link DES 1008D (DES-1008D) 8x10/100 Mbps...
Link/act LED of DES-1024D switch
The ethernet cable is probably damaged. If it is not... is the switch plugged in? Does it power on? Is the other end of the ethernet cable plugged into a live host?
Jun 08, 2009 | D-Link DES-1024D Express EtherNetwork...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
1,329 people viewed this question
old marine
old marine
