Can I replace the 40gb HD in my Denon DNV755 or do i need to send it out for repair
  • 32,281 Answers
Yes you can replace it yourself.
The only problem is, it is virtually impossible to get a 40Gb hard drive. The smallest new hard drive available now is around 100Gb but the BIOS in your computer most likely cannot support a hard drive of this large capacity.
Posted on Mar 31, 2011
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
I bought my ps3 in january 08 its a 40gb a couple of days ago i went to play it the sound is fine but the picture is not coming up i took it to my neighbours and it didnt work on his telly either i think...
You can have it repaired at:
PS3 Yellow Light of Death Repair using Infra Red UK
or if you have the receipt, you can have it replaced under the Sale of Goods Act. Anywhere up to 6 years after the date of purchase.
To do this you just need:
Independent PS3 fault report UK
Stating that the fault was there at time of manufacture.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
I have a Denon AVR-3801 but the remote is broken. Where do I send it for repair?
Remotes aren't worth repairing; they're replacement items.
A universal remote is the easiest to obtain.
Original replacements may or may not be available for this older equipment. Try contacting Denon customer support. If they have one, you may have to order it through a local dealer.
If you really want the original remote, maybe you can find a local tech who can check the battery connections and the output LED and possible fix it - but expect to spend $50 or more.
http://usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-3801&imageField.x=13&imageField.y=12
Nov 15, 2009 | Denon AVR-3801 Receiver
My Denon hd 2500 will not recognize my 500gig HD
first of all , 500gig its a lot and its not recomend to used such a large hd, second, the hd probably its not format in FAT32, mostly of the external hd came format in ntfs, but all the media player such ipods or dvd media players or even the dn2500 used fat32 format, so you need to copy all your music to another hardrive and format the 500 gigs to fat 32, but in my opinion you should organice better your music i dont thing you ever will used 500gigs and the data base its so large that it will take forever to load.
Apr 15, 2009 | Denon DN-HD2500 MP3 Player
No sound for HD channels Denon 2307
Need more detail - What is your TV source (directv, cable, etc,) Also - how is it connected to the Denon?
Apr 01, 2009 | Denon AVR-2307Ci Receiver
Replacement of 40GB HDD for Toshiba Satellite M35X-S114
Yes you can install a larger HD and if you save alot of stuff on your computer then yes it would be good to do this.
Dec 17, 2008 | Toshiba Satellite M35X-S114 Notebook
Can I replace a 40gb HD w/a 80gb HD
Your motherboard supports 80gb Hdd.No problem you will go for that
Jan 23, 2008 | Computers & Internet
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
