Question about Optoma HD8000 Projector
I have an Optima HD 8000 DLP Projector and have had it for a year. The issue I am having is that the projector works find but for only 3-5 minutes and then it turns off and the Lamp Indictor turns on. Any reasons It would do that?
  • Optoma Master
  • 6,694 Answers
First of all check the lamp hour of projector. just reset the lamp hour and try again.
1. Press the menu button
2. Select system
3. Then select lamp reset
4. Select reset
The lamp hour will be retested.
Try to do this before you projector turns off. it is recommended that do this only after replacing the lamp.
If doesn't work then check the following
Check the lamp cooling fan of your projector . may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Posted on Mar 31, 2011
I have optima hd71- ceiling mount hooked to hdmi sattelit tv-and samsung home theatre - hd channels give me full screen- normal channels with 16:9 does not - have 2 vertical grey bars -tried all adjus
You're projector is most likely fine. Check your satellite box. Go to the menu and see how its set to display video. It may be trying to up-convert TV signals. Try different adjustments from there to see if you see any change.
Oct 27, 2014 | Optoma HD71 DLP Projector
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
I have an Optoma HD 8000 projector and while watching TV the lamp will turn off what can I do to repair the issue
if the lamp, lamp driver,power supply,Scaler Board and Formatter Board were good.
perhaps it is over temperature protection.
whether you checked with the air filter( dust filter) is clean or dirty?
Jul 02, 2014 | Optoma EP7155 DLP Projector
Blotches screen
the problem may be from power cord. call a service center for checking the power cord.
May 03, 2013 | ViewSonic PJD6381 PROJ XGA DLP 24001...
My benq MP 512 shuts down after a few minutes of use. when it shuts down all 3 light indicators are off, fan also goes off.
DONT WORRY THIS IS A REGULAR PROBLAM OF BENQ ,DELL,INFOCUS PROJECTORS UR MAIN POWER SENDER IC IS DAMEGED THROUGH UR PROJECTOR AND BUY EPSON,HITACHI,SANYO PROJECTORS
Mar 12, 2012 | BenQ MP512 SVGA 2200 ANSI 25001 22KG...
Projector performance
I've been reading that indicates a dying lamp bulb.
Jul 02, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma HD8000 Projector Logo
156 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
