I want install oracle 8i in windows 7 - Computers & Internet
  • 18 Answers
You can't install that Oracle version directly on a Windows 7 machine, but you should be able to install it on XP Mode.
Oracle 8.1 is not supported on Windows 7. It is never intended to be used on Windows 7. You have to look at virtualisation (Virtual Box, Virtual Pc, WMware), to get Oracle 8i installed on Win XP, 2000, 98.
Posted on Mar 31, 2011
How do install 8i inwindow 7
actually there is no version released yet for windows 7
you can try windows 2008 .
Dec 30, 2010 | Veritas Cluster Server for Solaris Oracle...
Sir, please provide me with the soloution and my problem is that my client have a system which have window 7 and the client is using mstar which runs on oracle 8i and when i install the oracle 8i it is...
I am sorry to say but oracle 8i is not compatible with windows 7. If you would like this to run you would be needing a downgrade to xp. But if you insist on using windows 7 what you could do is install a virtualization software like virtualbox and install windows xp on it and the software you need. So, it would be like running windows xp in windows 7.
Apr 29, 2010 | HP Pavilion a1610n PC Desktop
How to install oracle 8i in windows 7
Oracle 8i is never intented to be used on Windows 7. Oracle will not support it. I think you have to look at virtualisation (Virtual Box, Virtual Pc, WMware), to get Oracle 8i installed on Win XP (or Win 2000/98).
Mar 11, 2010 | Computers & Internet
I want to install oracle 8i in windows 7, how i do this?
sir, i have a window7 in all in one hp but there is a software called mstar which run on oracle 8i when i install the oracle 8i there is a problem and show dll file corrupted. Pls tell me the solution because my client want it very urgently and i am not able to install and run the programm.
Feb 26, 2010 | Veritas Cluster Server for Solaris Oracle...
Step by step guide to installing sap on windows 2003
hi dear
SAP4.7 Installation On Server 2003 SAP 4.7 INSTALLATION GUIDE 1. CREATE C PARTITION 6GB AND D PARTITION 70GB. INSTALL O.S SERVER. SET SYSTEM YEAR TO 2010 OR 2. CREATE LOOPBACK ADAPTER. START→ SETTINGS→ CONTROL PANEL ADD OR REMOVE HARDWARE→ NEXT→ NEXT→ SELECT ADD ANEW DEVICE NEXT SELECT WANT TO SELECT THE HARDWARESELECT NETWORK ADAPTER SELECT MICROSOFT NEXT NEXT FINISH. 3. CREATE IP ADDRESS MY NETWORK PLACES LOCAL AREA CONNECTION RIGHT CLICK PROPERTIES SELECT INTERNET PROTOCOL (TCP/IP)ADDRESS CLICK ON PROPERTIES AND IN IP ADDRESS 200.200.200. 20 AND OK OK 4. VIRTUAL MEMORY MYCOMPUTER RIGHT CLICK PROPERTIES ADVANCED TAB CHANGE SELECT D DRIVE INITIAL SIZE 2000 MAXIMUM SIZE 2000 CLICK SETOK OK OK 5. COPY ALL THREE DVD IN D DRIVE. SEE THAT D DRIVEMUST HAVE ATLEAST 54-55 GB FREE SPACE. 6. JAVA 1.4 INSTALL [FROM DVD 1] JAVA 1.4 DOUBLE CLICK NEXT I ACCEPT NEXT NEXT NEXT FINISH. JAVA PATH MY COMPUTER RIGHT CLICK PROLPERTIES ADVANCED ENVIORNMENT VARIABLE [SYSTEMVARIABLES ] SELECT NEW VARIABLE NAME JAVA_HOME VARIABLE VALUE ----------- START RUN BROWSE SELECT DRIVE PROGRAM FILES ANDPASTE IN VARIABLE VALUE BOX {Enter Path of JAVA) OK OK OK . 7. ORACLE 8I INSTALL [FROM DVD 3 ] ORACLE 4 NT I386 SETUP ORACLE 8I NEXT NEXT NEXTGLOBAL DATABASE NAME ORA NEXT INSTALL FINISH [ OREXIT] 8. INSTALLATION . [FROM DVD 3] KER NT I386 NTPATCH R3 DLLN DOUBLE CLICK ON THIS PRESS OK. KER SAPINST NT SETUP. SAP 4.7 INSTALLATION SELECT THIS AND PRESS NEXT NEXT SYSTEM ID ----- GIVE ANY DIGIT ALPHABETS [EX: SAI] NEXT SELECT CENTRAL INTANCE NEXT NEXT SELECT LOCAL INSTALLATION NEXT NEXT SELECT C DRIVE NEXT ------- GIVE PASSWORD AS 123 IT WILL ASK TWO TIMES THATPASSWORD NEXT 9. AFTER INSTALLATION OF ABOVE STEP GO TO : \ RIGHT CLICK ON USR SHARING & SECURITY SHARETHE FOLDER IN SECURITY TAB TICK ALL ALLOW. GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ONPREPARE NEW INSTALLATION. THEN AGAIN GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ON SAPINST SERVE WITH GUI. AGAIN FOLLOWS THE STEP IN STEP 8 WITH THE FOLLOWINGCHANGES. SELECT DATABASE INSTANCE INSTEAD OF CENTRAL INSTANCE SELECT LOCAL INSTALLATION NEXT NEXT SELECT D DRIVE D DRIVE} FOR BOTH OPTIONS NEXT NEXT IN PACKAGE LOCATION GIVE THE ADDRESS OF DB1-----ETC. DB1 EXPORT 1 LABEL.ASC DB2 EXPORT 2 LABEL.ASC DB3 EXPORT 3 LABEL.ASC EXPORT 4 LABEL.ASC EXPORT 5 LABEL.ASC EXPORT 6 LABEL.ASC EXPORT 7 LABEL.ASC NEXT NEXT. SELECT THE OPTION NO MNLS REQUIRED AFTER THIS IT WILL TAKE 15 HRS FOR INSTALLATION. ITWILL SHOW SUCCESSFULLY INSTALLED. 10. GO TO GUI GUI WINDOWS WIN32 SETUP. ã NEXT NEXT SELECT ALL NEXT INSTALL. 11. AFTER THAT CLICK ON SAP LOGON IN THAT CLICK ONNEW ITEMS DESCRIPTION ANY NAME APPLICATION SERVER TO KNOW THISOPEN SAP MANAGEMENT CONSOLE, IN THAT CHECK THE NAME ABOVEPROCESS LIST AND FILL WITH THAT NAME. SYSTEM NUMBER 00 12. CLICK ON LOGON USER ID DDIC PASSWORD 19920706. THEN GO TO SU01 TRANSACTION. GIVE THE USER SAPUSER (this is the user name to logon to sap) THEN PRESS F8. GIVE ANY NAME IN LAST NAME INITIAL PASSWORD REPEAT PASSWORD. THEN CLICK THE TAB PROFILES GIVE SAP _ALL SAP_ NEW & THEN PRESS ENTER & SEE IT WILL ASK THE PASSWORD , THIS IS THE PASSWORD TOLOGON TO SAP, GIVE ANY PASSWORD AND LOG OFF. 13. AGAIN LOGIN TO SAP NEW ID & PASSWORD AND THEN GOTO SE38 AND CREATE A PROGRAM STARTING WITH LETTER IT WILL ASK FORACCESS KEY. IN THAT TYPE 366 87 66 322126 127 8 694. Thank you
Imrna
Pls rank me as possible have nice day
Apr 20, 2009 | Microsoft Windows Server Standard 2003 for...
ORacle 8i on Windows Vista
You wont be a ble to install Oracle 8i to Vista computer ,because that Oracle version is not supported on that Vista OS (only 10g onwards) will work with Vista computers.
Hope that helps........
Sep 12, 2008 | Computers & Internet
Oracle 8i on Windows2000Server
What exactly motherboard & processor you are usin? For some latest mother boards Oracle8i will not install and terminates why because the interface of the oracle was devloped by developed by using swing (java) so some app's wont start. This might be the cause. So, what you have to do is copy Oracle8i CD to HDD and search for SYMJCIT.DLL and rename it to SYMJCIT.OLD and install from the dump.
If it wont work then reinstall the system once.
This might be helpfull
Thank you
Nandu :)
Jul 18, 2008 | Microsoft Windows Server Standard 2003 for...
Installing oracle 8i
That is the problem with XP...Those softwares which were workin is not supported by XP...(different platform)...or else go for the software developer and get the XP version
PLEASE VOTE ME AS FIXYA (blue boxes) for my help.........
May 23, 2008 | Computers & Internet
Windows xp pro oracle 8i database access very slow
check your computer comfiguration check the ram for memory
Nov 28, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
