Question about Dryers
Hi i have a hoover 5030D cloths dryer and it dosent heat up when in use can you tell me if im able to repair this my self and where i can get parts. regards Bill
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 31, 2011
Hoover 5030d dryer I have to spin the drum to let dryer work. What is the problem? Where can I find the spare part?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Dryers
Hoover dyrer 5030d not getting warm
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 03, 2011 | Hoover Dryers
Hello, i have a hoover dryer, model 5030D, secondhand, it is just been purchased my us. we put on our first load on and the machine stopped within 15minutes. we noticed then that the machine was...
Hi, if I remember correctly this model originally came with 2 faceplates so the controls can still be easily accessed, when the dryer was installed upside down on a wall. Most dryers can be run upside down, or even on their side as I done in the past with my Hoover 5030D, so the problem would lie elsewhere.
Dec 26, 2010 | Hoover Dryers
My Hoover dryer model 4030D heavy duty needs a new
HI. you can order your timer by calling this number. this is a parts store that will ship your timer to your door step or mailing address..
1-866-925-PART (7278)
Just tell the Representative your model number and brand name of the affected unit and, they will search for it on there data base. when found, they will ship it to you after you purchase it.
Jun 18, 2009 | Hoover Dryers
I have a wall bracket on the laundry but hjow do I get the dryer on to the bracket
Is the wall dryer bracket, the correct one to fit your hover
May 28, 2009 | Dryers
Drier
I just saw this model advertised in Australia online and they said, less than a year old!
model 5030D???????????????????
I would not buy a used appliance!
Just putting good money into bad. Unless I can afford to fix it.
And I f so I would be better buying a cheap new one and take the extended warranty in today's market.
But everyone's not me!
Huuum
Sep 23, 2008 | Hoover Dryers
I have a Hoover 5030d & its making a noise as the barrell turns. If spun manually it sounds a bit like a bearing. Is it easy to change a bearing on a Hoover 5030d?
It sounds like the engine shaft bearing. Fairly simple to fix or replace with the correct tools and know how.
Be sure to take photo's of the motor, tension arm, and any wiring.
You'll need pliers to remove the clamp from the fan, then remove the belt from the motor and make sure that's were the problem is before going any further.
Jul 06, 2008 | Hoover Dryers
Dryers Logo
109 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
