Question about Labtec Pulse 424 Computer Speakers
I have the Pulse 424 speakers and they are like 8 years old. The speaker with the power and volume knob is out. It works to turn on speakers and control volume but no sound. The woofer and the other speaker sound great but would love to have all 3 speakers working. My control panel/device manager states everything is fine and updated. Do I have to buy another system???
  • Labtec Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 31, 2011
`Have trouble adjusting volume.When i try to adjust the volume tone is very scatchy and breaking up..something seems to be wrong with volume control knob.
1) Turn your speakers off.
2) While blowing a can of compressed air into the switch, twist the knob up and down a bunch of times.
3) Repeat step 2 for roughly 10 minutes, blowing the dust out of the volume controller.
Try it again..
Good luck!!
Apr 05, 2011 | Dell A215 Computer Speakers
Speakers have no sound
Please check the below mentioned things :
Verify the AC power cord is plugged into the wall outlet. Turn the VOLUME knob on the right speaker until you hear a click sound. An LED will light next to the knob when the power is ON. Turn the VOLUME knob clockwise to raise the volume. Check volume level on the computer sound card or alternate audio source device, and set at mid-level. Check plug connections on the audio source. Make sure the signal cables are inserted firmly into the correct jacks. Make sure the 3.5mm stereo cable is connected and fully inserted into the "line-out," "audio-out," or the headphone jack of the audio source. Test the speakers on another audio device. Remove the 3.5mm stereo cable from the audio source device and connect it to "line-out," "audio-out," or the headphone jack of another audio source.
And if in in case u r unable to get it working ..
Replace the speakers ..
Jan 24, 2011 | Altec Lansing VS2120 Computer Speakers
Re: Boston digital BA735. Hum with or without input signal.
Hmmm I just got the same problem. They worked fine on my old Dell desktop but when I plugged them in to my son's old Dell PC (maybe 1 year newer than my old one) they all hum like crazy - as you say even if it's just the power plugged in and nothing else. Yes it does have the original power supply. I get no music (but still it hums) from digital out/in but when I switch to analog out/in I hear the music and it still hums, plus the sound is distorted. Wierd.
Jul 14, 2010 | Boston Acoustics BA735 Computer Speakers
Only one computer speaker recieving a signal
Most probably there is a problem in the cable or plug.
Feb 06, 2009 | Boston Acoustics BA735 Computer Speakers
Logitech S500 Volume Knob Broken
The simplest thing to try is some compressed air directed to the knob. This would clear out any dust or dirt that may be obstructing the knob. I am not sure what you mean by power cut so I am shooting in the dark here. If you mean a power surge that caused the volume to quit working then I would suggest an external volume control such as http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=pd_bbs_2/002-2257004-6895258?ie=UTF8&s=electronics&qid=1194009359&sr=8-2
Or
http://www.radioshack.com/product/index.jsp?productId=2102975&cp=&sr=1&origkw=volume+control&kw=volume+control&parentPage=search
Dec 18, 2008 | Logitech X-540 Computer Speakers
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
Sep 18, 2008 | Audio Players & Recorders
Volume knob problem
This is a problem with poor cold soldering at the bootom of the volume pot, what has to be done is slowly seperate the glued seem where both speaker halfs are "glued"LOl... yes glued together,...Use a small flat head screw driver of any sort and work the way around it and it will seperatel and then resolder the volume pots circuit board pins, then use ABS to glue it back together, dont foregt to get the blue LED power light indicator set right before pressing both sides together.... (^_^)
Aug 21, 2008 | Altec Lansing VS2121 Computer Speakers
Loud crackling / popping
Well gd stuart i think you need some new speakers
Jan 27, 2008 | Logitech Z-2200 Computer Speakers
Volume goes up and down by itself
  • i think the problem is due to dust
  • using a vaccum cleaner or use a painting brush for clean the IC legs and ciruit
  • check loose conection of the control
  • the dust mis function the chip inside
wish you all the best
Jan 17, 2008 | Creative Labs Inspire T2900 Computer...
Labtec Pulse 424 Computer Speakers Logo
132 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
