Question about Peavey ValveKing 100w All Tube 212 Combo Guitar Amplifier
I have a peavey valvenmaster head that was playing at very low volumes even when cranked up pretty loudly. i replaced all of the tubes with new matched groove tubes and the volume and tone improved. after playing for several hours at about half cranked up, the fuse blew. i'm not sure what could be the cause. i have a meter and know how to measure voltage and etc. but i don't know where to start after discharging the capacitors. help?
  • Peavey Master
  • 5,603 Answers
You start by downloading the schematic here:
http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Scroll down to the link "Get Manual" and download the schematic. Note that it has several pages of parts list preceeding the schematic.
Next, put a 150 Watt incandescent bulb in series with the power cord to act as a current limiting fuse. Now replace the fuse and proceed with testing. You may find that one or more filter caps have shorted. Also pay particular attention the the BIAS power supply. You should see about -35 to -40 volts. Note that the series lamp will come on if excess current is being drawn and voltages will be low if the lamp lights. If the BIAS supply has failed, it is possible your power tubes have been damaged.
Posted on Mar 31, 2011
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
I have a peavey renown 400 while playing bar chords at 3 to 4 on volume amp will get loud and distorted on its own never shuts off though. but only happens bar chords 7th fret and above.mind baffling
Could be a few things, most simple the Tubes, and or biasing, I have had a few amps that certain notes or chords would cause harmonic distortion within the tubes, and the tubes where good? Another possibility is the output transformer? Sometimes when they are failing the volume varies... hope this helps?
Mar 04, 2015 | Peavey Music
Peavey problems
cracked solder joints, how old is it, they have 5 year warranties..
Aug 02, 2014 | Peavey ValveKing 100w All Tube 212 Combo...
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
Brand new Peavey 6505. Worked fine first day but now just blows fuse and doesn't even turn on. Will be going back but has anyone got any ideas?
Something internally has shorted...not a good indicator of this models reliability. It may pay to research another replacement brand.
Dec 28, 2013 | Peavey 6505 120w All Tube Head Guitar...
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
My Peavey vk100 head is running through a Carvin Legacy 2x12 cab. On the clean channel there is an inconsistent popping sound. It will happen loudly for a few seconds, and then not at all for a while, and...
You may simply be overdriving the clean channel and causing it to "flat top" . See if it occurs when you back the gain down a bit. New tubes PROBABLY will not help and be a waste of money. You may be unconciously playing harder during the popping episodes. You cannot hear level variations smaller than about 3 Db BUT the electronics will sense much smaller variations. You could gently tap the tubes with a lead pencil to listen for any pops... NOTE: tubes can be slightly microphonic so some sound from tapping is normal.
Yes, a cable can be noisy and not show itself when using intentio0nal distoprtion... try another to verify it is not the problem.
Jan 02, 2011 | Peavey Valveking Vk100 Guitar Head
I have a peavey supreme xl head thats... well... OOOOLD. at one point i got SUPER pissed and kicked it across the room, causing one of the speaker ouput jacks to fall out. I put it back in and, for a...
Open the unit and inspect for damage and repair as necessary. It does no good to just look at it. Likely something has fallen into the speaker and damage could be worsened if you don't repair it before trying to use it,
Feb 11, 2010 | Peavey Music
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Peavey ValveKing 100w All Tube 212 Combo Guitar Amplifier Logo
236 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
