Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Model # GLTF1670ASO
Washer takes a lot longer to go through a complete wash cycle.
  • mlnelson Aug 13, 2008
    Thanks. I have done that and it worked. I used a shop vac to **** out the drain tube and out came a penny. Also cleaned the ingoing cold water and we're down from over 2 hours a load to under an hour.
  • 725 Answers
Check you drain / drain pump... slow drain will cause a long time wash
Posted on Aug 13, 2008
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
On my 6.3 yr old frigidaire front load washer (model GLTF1670ASO), the wash cycle does not dispense the water, but the rest of the cycle works fine. In other words, the washer tumbles dry clothes thr
sounds like the pressure switch is stuck its located inside the washer it has a small tube on it that is connected to the pressure chamber on the outer tub these block up with old soap ext and you have got to take the tube off and blow or unblock with a small wire
Nov 21, 2011 | Frigidaire GLTF1670A Front Load Washer
Basket seems to be unstable and during the spend cycle it?s really loud. (Model GLTF1670ASO)
does the inner basket seem to move side to side or up and down relative to the outer tub? If so, you probably have a corroded spinner on the back of the basket. this seems to happen in reaction to certain water quality issues or detergent combinations.Most often if this is the case, my customers opt not to fix the washer unless it is in warranty
Apr 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Cycles take an exceedingly long time to complete
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
Sep 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Dec 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Washer Model # FWS1399EC
The selector knob has gone bad. The selector will have to be replaced. I've seen a lot of Frigidaires with the same problem.
Dec 20, 2007 | Frigidaire FWS1339A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
346 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
