Question about Sony Ericsson W200i Cellular Phone
I have charge my phone battery fully by multi phone battery charger bcz I cannot charge with phone. when put battery and power on my phone battery and board are being heat. within 10 minutes the battery going to low may i know what is the problem and solution for it?
    Sniper:
  • 57 Answers
Hello Sir !! Welcome to Fixya !! There can be either two problems.Either your battery is not compatible with the charger you are charging or battery is got damaged.I recommend you to charger your battery with the genuine charger.If it doesn't solve your problem replace your battery from the nearest customer services center. If this was help full please rate or token of appreciation will be esteemed. Regards.
Posted on Mar 31, 2011
  • sanjev1987 Apr 03, 2011
    I have replaced the new battery. That one also doing the same.... my charger is genuine....
  • Rizwan Siddiq
    Rizwan Siddiq Apr 04, 2011
    Dear Sir,
    Thankyou for considering our solution....
    we tried to check you problem with the most common solution, but as far as the results were not positive , we would like u to describe the root problem with you cell phone. The heating problem and ultra quick battery drainage problem arises because of the malfunctioning transmitter on the mother board of your phone. you will notice that whenever you initiate a call the battery consumes itself even more quickly... On the other hand, not charging problem is caused because of the damaged charging IC which is again located on the motherboard of the phone... You phone will be showing these problems because of either of them or even both... so the recommended fix for that is to replace the Charging IC first and use the phone for a day or two if the problem still persists go for changing the Transmitter... After that you phone will work fine... Thanx and dont forget to rate this if u find this usefull... Rizwan Inc. Fixya Team
Why doesn't the motorola P4000 not hold a charge after charging it for several hours
Your battery is shot. Rechargeable batteries only last so long.
Feb 08, 2015 | Motorola Cell Phones
How to tell if battery is full charged before using it.
The easiest and best way to test any battery is with a volt-meter.
http://www.northerntool.com/shop/tools/product_12496_12496
The link above is for a multi-meter. These are inexpensive and are an extremely useful tool to have. For about $15-20 you can buy a meter which will test AC/DV voltage, resistance/continuity and often diodes and/or transistors as well.
A fully-charged 12v battery will give a reading of 12v (or very close to 12v) on a volt-meter when it is fully-charged. 6v batteries should read 6v, 1.5v batteries should read 1.5v, etc, etc.
If the reading is lower than the power output of the battery, the battery is either not fully-charged or one or more cells may be damaged. If cells are damaged, you will never get the full 12v output from a 12v battery.
There are other ways to test batteries but they are less accurate. It's possible to use a battery charger, but you can only use this to determine whether a battery is fully-charged if the battery is known to be good. A fully-charged battery should draw 0 amps on a battery charger, but a damaged battery may also draw 0 amps so this is not a good test.
Basically, I'd suggest you get yourself a multi-meter. You be glad you did!
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Mar 11, 2011 | 300 Amp Battery Jumper with Air Compressor...
Included in my Ryobi printed instructions are the statements: 1-"Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode. 2-"To obtain the longest...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
Dec 23, 2010 | Ryobi Multi-Volt Battery Charger
When i put my power pak in the light come and go right back of and it would'nt charge
Could be the battery is fully charged. Otherwise if the light goes on and off, then the battery may need replaced. YOu can buy them online at a reasonable price.
Sep 22, 2010 | Ryobi Multi-Volt Battery Charger
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Rokr e6
did that, both chargers work, fully charged both batteries. But when i plug the chargers into e6 it does not say charging battery and the battery symbol does not blink
Feb 16, 2008 | Motorola Mobility ROKR E6 Smartphone
Phone doesn't hold a charge
MzRendevous, It sounds like you do have a battery issue. Batteries for cell phone don't tend to last long, but if you do purchase a battery, try this to get longer life from the battery. 1. Charge the battery without using the phone until the battery is fully charged. 2. Once fully charged, use the phone like you normally do until the phone shuts itself down because there is no power. 3. Charge the battery again without using the phone until fully charged. 4. Then you can use the phone and charge it anytime you want. You can repeat these steps as much as you want, the more you do it, the more life you'll get from the battery. -- As far as the charger, if you have to adjust it to get it to charge, it could be the cord or the prong on the inside. I'd goto a store and test another charger, if it's available. You can probably get cheap batteries/charges on EBay or anywhere on the internet. Let me know if I was helpful for your questions. John
Jan 03, 2007 | Motorola Mobility V265
Sony Ericsson W200i Cellular Phone Logo
61 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
