Question about Dell Inspiron Notebook
Dell 1420 Boot issue
I was watching a video one day and my computer froze up. The screen flashed several times and eventually I had to hard reboot. Upon restarting, Vista told me that the video card driver failed, but that it recover just fine (yea, right ;) ). It did this several times. Now, when I turn on my Laptop (Dell Inspiron 1420 32bit), I don't get any image. I've tried hooking a monitor to the external display and hitting the f8 with function but it doens't switch. I would like to try resetting the computer via it's "factory state backup" but I can't see anything. The attached display does light up somewhat as if a backlight is working, but everything is black. Not even the bios is visible.The hdd seems to be working hard. I feel like it is a driver issue, I just don't understand how it could have gotten currupted since I wasn't changing any settings. I was however, watching a video through the s-video port to my TV. I am hoping someone will tell me my video card has not overheated from this typical activity, and there will be an easy answer such as a failed driver. I have all the discs that came with the system. Many Thanks to anyone who can tell me how to solve this!
  • alanudi Aug 05, 2008
    Well I managed to start up a built-in diagnostic program by pressing "Fn" and the power button together with the system turned off. My screen all the sudden started working correctly. It checked my pc and found no problems. I then went to a repair option by pressing F8 when it rebooted again. This allowed me to run a system startup diagnostic. This suggested a system-restore and did so automatically. The computer booted up fine after that. I am now backing up many files I should have backed up before and will be utilizing the "factory settings restore" feature and will hopefully be back up and running. Thanks for the input!
    Genius:
  • 2,028 Answers
O.k. First off a corrupted driver can be as simple as a glitch, and software glitch all the time, it's normal. In this case, it's not a driver, it's going to be the video card. The reason is that the video has a generic driver built in, this allows you to be able to see what you're doing when initially installing the system, then after the install, you download the driver for the particular video card in the machine for the maximum performance. The generic driver also works for any external monitor, until you download the driver for the external, if it supports one. Since the external didn't work, this indicates that the video card has failed and will need replaced. Without being able to view anything, you will not be able to download any drivers or do a bios flash to correct the built in generic driver. The generic driver rarely ever fails and I've never seen a failed, corrupt, or glitched generic in the seven years I've been working on laptops. Take it in for a professional diagnostics if you like, but most likely you're going to have to replace the video card.
Posted on Aug 05, 2008
My Dell Inspiron 1420 screen goes black
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 02, 2012 | Dell Inspiron 1420 Notebook
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1420 laptop. I left it running overnight and when I checked in the morning the screen was moving up and down. I tried playing videos in full screen and it does, too. It seems as...
boot in the safe mode, see if issue still occurs (F8 at boot) if it does, then likely there is a problem with the Video Card or the LCD itself, I'm leaning toward the video card.
Try flashing the bios to current and installing the most current video driver, see if anything changes.
Sep 05, 2010 | Dell Inspiron 1420 Notebook
Nvidia card on dell 1420 no image on screen on boot up
Restart the computer in Safe Mode with Networking by continuously pressing F8 at Dell logo. Go to the Nvidia website and download the latest drivers for your machine. If you are experiencing no video whatsoever, then either the screen needs to be replaced or a connection is loose or not working behind the screen.
Mar 20, 2010 | Dell Inspiron 1420 Laptop
Hello, I have a Dell D600. and the screen froze the other day. I did a hard restart and now the screen is pitch black at startup (but the systems seems to be running). Please help
The first thing to do is determine if the system actually is running or is it in a no POST configuration.
  1. If you are getting any video at all (Dell Splash Screen at boot) then try booting into the Safe Mode (F8 at boot) If you can get into the safe mode, then try a system restore to the day before the issue
  2. If you are not getting any video, then try using an external monitor and toggling it on with FN + F8 If you get video on an external display, then there is an issue with the LCD most likely and I'd try reseating the video cable under the keyboard as a place to start.
If you are not getting any video, then try this: http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 12, 2010 | Dell InspironTM 1501 Notebook
Dell Inspiron 1420 will no longer boot
you need to enter setup by tapping one of the f keys or the delete key. i'm not sure which it is for this model. when you enter the bios setup change the boot order to boot to the dvd first. hit f10 and save the change then reboot with your install disk in the drive. it should start installing.
Sep 06, 2009 | Dell Inspiron 1420 Notebook
Dell inspiron 1429 would not stop restarting
just read the error on that blue screen...Its a dump error....then tell me....
ashishcgaikwad@hotmail.com or on 9665071117
Aug 27, 2009 | Dell Inspiron 1420 Notebook
6 monitors on 1 screen!!!!
try booting to safe mode (F8 at boot) and see if the issue goes away. If it does, then reboot in the normal mode see if the issue still occurs.
If it does, try running systemre store to a restore point before the issue started.
Mar 06, 2009 | Dell Latitude D600 Notebook
9300 display issues
sounds to me like u r video card has an issue, or it could be the display on it's way out, that problem is really hard to resolve without personally looking at it and toy around with it, I would suggest contacting Dell tech support chat and let them go inside remotely and check it out inside and run a diagnostics on it, if you shut the system off and then restart it and hold the Fn key down you unit should run a diagnostics that should tell you your problem.
hope this helps out and let me know what you find out!
Thanks
Dennis
Jun 16, 2008 | Dell Inspiron 9300 Notebook
Dell Inspiron Notebook Logo
141 people viewed this question
Alun Cox
