Question about Cameras
How do you install a capture model cr4vehd digital video recorder with a vandal proof ir vari-focal dome camera
SOURCE: I have an analog video cam recorder. How could I
Well you can send the Video Out from the camcorder, to a "Video In" device and record it to your PC's hard Drive. Then you could "Burn" them to DVD or simply play from the PC. You can get USB to Video In devices that have SVGA or Composite Video in. also some Video cards have this feature, Video In, as do TV cards for the PC.
Posted on Feb 01, 2010
Habubnik
  • 114 Answers
SOURCE: MOV format
The MOV format is an industry-standard format used by many digital still-picture manufacturers. As with the JPEG format used for still images (the primary purpose of EasyShare cameras), the MOV format provides a video capture file that can be used on most computer operating systems and platforms. Kodak EasyShare digital cameras include the free Apple QuickTime player software. If you are interested in more sophisticated editing capabilities, many MOV editors are available from several companies: QuickTime Pro from Apple Computer Inc. is the initial upgrade package to the free QuickTime player software. Search the Internet using the phrase "QuickTime editing" to find many other sources of QuickTime editing software with a wide range of capabilities.
Posted on Aug 29, 2005
Quack
  • 542 Answers
SOURCE: putting video footage on my computer
To get your footage into the computer from DV tape you need a four pin firewire (IEEE1493 or iLink) cable from the camera to a six pin cable into the computer. USB will not do a proper job, it's for downloding photos or as you already mentioned, Web caming.
Posted on Sep 15, 2005
Drawsalot
  • 38 Answers
SOURCE: i need a driver
Sony's website says: "Some digital camcorders must be setup to output a signal through the i.LINK® port prior to being connected to a computer. Consult the instruction manual of your camcorder for specific information before continuing with the steps in this solution. Instruction manuals are available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the i.LINK cable is connected securely to the camcorder and computer.
  2. Ensure the camcorder is turned on and being powered by the supplied AC power adapter.
  3. Ensure the video capture card and software are configured properly to receive the i.LINK signal from the camcorder.
  4. NOTES:
    • Depending on the video capture card and software you are using, you may need to manually configure the capture card and software to receive a signal from the i.LINK port. If applicable, check the Help files of the software or contact the video capture card or software manufacturer for further information.
    • Sony® digital camcorders are not provided with and do not require special device drivers for i.LINK connectivity. The device drivers that allow i.LINK connectivity should be provided with the video capture software. If the software you are using does not appear to have the required drivers, you will need to contact the software manufacturer.
Likely this is the case where the camcorder needs to be setup in order to connect to the Firewire port. This is done inside the menus. Windows XP and Windows Vista will detect a camcorder connected to a Firewire port automatically. Make sure your camcorder is powered up and configured before connecting it. Does your PC have a Firewire port? Many do not, PCI cards with firewire ports can be bought online or from local retailers. Some sound cards come equipped with one.
Posted on Nov 18, 2007
  • 24 Answers
SOURCE: JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Posted on Jan 21, 2008
What is the difference between a simple day/night IR cameras and day/night IR cameras with IR Light?
The IR lights light up your subject with light that they can't see but the camera can in order to get higher quality recordings
Oct 16, 2013 | i-rocks IR-3230 Webcam
I cant hear the videos i have recorded on my camera i have installed it all but cant hear any volume to play back the video on the camera and my laptop
The 7024 is designed primarily as a still camera, with some video features grafted on. As such it captures images not sounds. You can add a soundtrack using video editing software on a computer, but you cannot record one on this camera.
Dec 31, 2010 | Vivitar 7024 Digital Camera
Dome camra wire connection with bnc
Preparation
Before installing your RCA camera scout the area and confirm that you will be able to run the cable from your surveillance digital video recorder (SDVR) to your camera. You may want to use RG59 Siamese cable, which is a single cable system with three wires: a coaxial cable for the video and a positive and negative wire to provide power to the camera. If you are installing your camera outside, place it at least 10 feet high to minimize tampering, or put your camera in a dome or other protective housing.
Coax Cable
BNC connector
BNC connectors and cable image by Albert Lozano from Fotolia.com
BNC connector
If you use Siamese cable to wire your RCA camera, you will run the cable first, and then install a BNC (bayonet Neill-Concelman--named for the inventors) connector on each end of the cable. BNC connectors vary by manufacture; install the BNC connectors according to the connector instructions. To get a general overview of the process, see the Resources section for a video on installing BNC connectors.
Power Wires
Plug with standard lamp-type cord
element electric power black image by Leonid Nyshko from Fotolia.com
Your camera came with a power supply with an integrated power wire; the power supply plugs into a standard wall outlet and the other end plugs into your camera. The cord is probably not long enough, in which case you will have to cut it and splice the Siamese in the middle to deliver power to your camera. The power supply wire is designed like a standard lamp cord and must be cut in half and split. One of the wires will be marked with a stripe, a series of dashes, a rib on the insulator or some other marking (just like a lamp cord). The marking indicates that this is the positive wire. After cutting the supply cord, connect the portion with the camera plug on it to the Siamese cable at your camera and then connect the power supply portion to the other end of the Siamese cable near your SDVR. The positive (marked) power supply wire should be connected to the red Siamese wire and the other wire connected to the black Siamese wire. While many people use wire nuts to connect the wires, connecting the wires with a wire beanie (see Resources) will provide a higher quality installation.
Plug-and-Play
Plug-and-play cables make it easier for homeowners to install their cameras. These cables incorporate all three wires into one cable system and come with connectors preinstalled so that you will not have to install connectors or cut wires. This is slightly more costly than assembling your own cable, but it will save you time and you will not have to purchase special tools to install the connectors. Run your plug-and-play cable and connect it by following the instructions which come with your cable. See the Resources section for a video on installing plug-and-play cables.
Dec 16, 2010 | Dome (8) Cctv Dome Color Ccd Night Vision...
How to transfer files from sony digital video camera recorder dcr-trv265e pal to my windows xp computer?
If your camera has FireWire, you can install a FireWire card, Or USB "Dongle" into your PC, Or you can install a TV/Video "Capture" card Or USB dongle, to your PC, then using Video Capture Software, essentially, making the PC into a DVR, you can then record, and save it to disk, and then you can do with it whatever you wish.
Apr 01, 2010 | E.Digital Sony DCR-TRV265E camcorder Pal
Videos have no sound
Many cameras that capture videos, don't have a microphone to record the sounds.
For all that the Vivitar 5022 does have, a microphone is not one of them. There is no sound recording capability for this model.
Jan 18, 2010 | Vivitar ViviCam 5022 Digital Camera
1/3" SONY ir camera car-b3110hq. dc12v pal. Black horizontal lines scrolling up the screen. About an inch wide. Camera still working though. Intermittant fault seems to come back when the auto focus...
It seems that the power adapter in for for you country. It may be a import. Normally adapters can handle 50/60Hz but not good adapters or false adapters or adapters made for certain region are unable to handle both frequencies. This is normally the cause of the stripes you are seeing.
Cheers
TeaCii
If you own website, add live support almost free
Let real security guard watch your cam for $1/day
Jan 15, 2010 | Sony 1/3 inch CCD infra red CCTV Security...
Sony analogue Hi8 Handycam as a security camera
Hi!
You need to have things with you before you can proceed to use it as a security camera. As your's is a analog camera we will require a video capture card connected with your pc/laptop.
After you have one connect that with your pc and pTo get the video into your computer, you need a analogue to digital video capture card....otherwise, connect the camcorder to a CD or DVD player/recorder, and use the CD/DVD as a source for your video editing... Otherwise, you need a later model of SONY "Digital 8" digital camcorder which plays analogue tape, and with this your computer can capture the video via firewire
For details on how to record using a software and video capture card please look at this link---
Handycam as Security camera
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 06, 2009 | Sony Handycam CCD-TRV68 Camcorder
Camera picture
Let me preface this by my expertise with Pelco Products.....I have been working for Pelco for over 8 years now......So I need to know what the model number of the camera in you DF5 dome is because that Dome Pack number is not a valid part number....Here is how that part number brakes down...the DF5 tells me its a DF5 Dome and the UY is the section of that part number that doesn’t make sense...its not a valid number it should be either a CA ,MA or CC and the 0V21A tells me that it has a smoked bubble with the 13VD2.8-12 vari-focal Auto iris lens...... On a different note we do not make a fixed camera that will fit in a DF5 Dome that can take up to 26-27VDC (Direct Current) So if you are using 26-27 VDC you might have damaged the camera try a 24VAC transformer instead.....Good Luck and the more information you can give to me about the camera that is in the Dome the better.....let me know if this helped..
cbinny1
May 02, 2008 | Pelco DF5UY 0V21A Domepak In Ceiling...
What is the distance at Macro mode?
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD(21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format). (Focal length is7.2mm. At maximum magnification 283mmx213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD(13cm from the lens front )and the magnification is 0.177x (equivalent to 0.7x in 35mm format). (Focal length is42.7mm to 50.8mm. At maximum magnification 50mmx37mm of the subject can be captured.)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Cameras Logo
211 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
