Lights around e machine power button flickers.
  • 4 Answers
May be the light around the power botton also acts as a activity light!
Posted on Aug 05, 2008
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
When you press the power button the red light flickers blue and back to red and nothing turns on
It sounds like you need a new power supply, You and find one on amazon around $14 too $18 dollars maybe less, if that not your issue then it's going to be a fuse but since you can see the light it should be the power supply.
Jan 07, 2011 | Polaroid FLM-2011 Television
My computer does not start when I depress the button. The light flickers once only.
At CompUSA, they sell an inexpensive power unit checker for around 10 bucks...it will check all the cable outlets for most power units and let you know if you have lost a main power rail.
May 21, 2010 | Antec 430-Watt Power Supply
Won't turn on...turned off while my son was on it...light around power cord is on, but battery light flickers/blinks 3 times when I push power button. Not sure what to do next.
You can try unplugging the power cord and taking the battery out. Then, re-insert the battery and press On/Off key. This will re-boot your PC.
Mar 18, 2010 | Computers & Internet
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
E-machine 5220 power up
Emachines have notoriously cheap power supplies. Often, while the power supply itself doesn't fail, it causes the failure of motherboard components, essentially trashing the computer.
Try the following:
First check and make absolutely certain that the power switch connector is properly connected to the motherboard. (Take standard grounding/safety precautions: wear a properly-grounded grounding strap, for example, when working with any internal components.)
Obtain a known-good power supply of equal or greater capacity to your eMachines PS and switch 'em out.
If either of these fixes your problem, well and good. If not, the problem may be, as is all too common with eMachines power issues, a motherboard issue caused by the power supply.
Jul 16, 2008 | E-Machines eMachines Desktop PC
My Hotpoint 960 is 18 months old and has develped a fault where the mains light and programmer display flicker simultaneously, and the machine cannot proceed through the programme. It does not respond to...
Flickering lights might just be caused by loose wires in the mains plug on the machine's power cable. I would suggest checking that first - for some reason the neutral wire seems more likely than the others to come loose. There might be brown / purple marks around the terminal inside the plug if this is the case. Also try replacing the mains fuse in the plug.
While you are there you might also try plugging a normal table lamp into the socket you use for the machine - if the house cabling to the socket is defective the lamp should flicker too.
If neither of these ideas is productive, the problem would appear to be within the machine, so please ask again. Good Luck D.
Jun 29, 2008 | Hotpoint Washing Machines
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
