My Airtec split level conditioner is not working properly. Blowing out air OK and all settings appear to work but not cooling. Display says E4. Is there a simple solution without calling in the repair man? Thanks
    Scholar:
  • 133 Answers
Is your compressor running?
Posted on Mar 31, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Error e4 sir air split unit
We have a SirAir Split unit Airconditioner, It's not cooling and shows e4 error.
Feb 27, 2013 | Heating & Cooling
Airtec S24H Air con Error Code E4 - what does this mean?
E-4 Short of gas or no gas/Abnormality of out door . Call repairman to check leak and arrest it Then vacuum the system and do gas charging.
Dec 29, 2010 | Heating & Cooling
E4 message no cool air. Heat is fine, fan and
If the fan inside works , the unit is probably low in refrigerant , or the filter is clogh with dirt.
Sep 27, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Power outage/AC not cooling
ok if you have split system if indoor fan runs then transformer is working you have 2 breakers 1 for indoor and 1 for out door also disconnect at unit may have fuse in it if all seem ok remove side cover and look at capacitor if sweeled up bad take an insulated object and push in contactor if runs check for 24v from common to yellow stat wires also look for reset button next to freon lines hope this helps
Jun 14, 2009 | Whirlwind FH-778 Air Conditioner
Ramsond split AC 12000
HI YOUR BROBLEM I THINK IS THE SENSOR FOR THE ROOM TEMP
Sep 02, 2008 | GE Quiet-Aire Ductless Split System Air...
WRAC has E4 on display
E4 means return air sensor error, if the error cannot reset may be the return air sensor is out of range or defective. But if the sensor is ok you need to replace the control board itself. The reading of return air sensor is 8k to 10k ohms @ 25deg. C temperature.
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
