I just got a Mitsubishi WS-A65 that has a issue, when I turn it on I dont get a picture, I do get some faint glow and some faint curved lines, I get error cod 1-2 which says no error and I have audio. When I turn the set on the green light goes to solid with no blinking, I cant see any menus so I cant adjust anything. Any Ideas
    Novelist:
  • 159 Answers
Hi, if you have audio and any kind of a blank/darkened screen then you either have a bad video hookup cable, defective video input, or a bad backlight system-bulb or power supply to bulb is probably weak from symptom you described. Hope this was of some help-if you can find a You tube of someone adjusting brightness you may be able to blindly hit right buttons to turn down brightness then turn set off then turn back on with a picture again-it's actually not impossible to do, I know because have actually done it once. Good luck, prodzilla
Posted on Mar 31, 2011
  • biohazard222 Apr 06, 2011
    When I first took the rear cover off the TV and looked in the lenses, I could see that the blue was on, I could not see that the green was on, and the red was on, but not as bright as the blue, so I got down and turned up the three colors so you can actually see the CRT's, now you can see the patern better, the curved line are made up of the three colors Red, Green and Blue, and you can see "Ghost" images of the picture that is playing in the background, and have good audio.
Mitsubishi WS-5541 light blue glow
I know these sets pretty well--worked on a lot of them when new and later--one of two possible ideas=
1. Either a odd convergence problem==confirmed or denied by going into the convergence menu (in customer menu) and selecting advanced which will bring up a grid of lines--if see the same issue (I will attach a photo of a Mitsubishi with this problem) it can be fixed.
2. Some sort of issue with the circuit board on the end of the Blue tube(you are missing blue=black) but usually in this set if that happens it is uniform and on both sides of the screen, not the top.
Let me know what you find.
I doubt it is convergence, but does not hurt to look--if the missing area was perfectly rectangular I would suspect up/down centering adjustment.
There is one other possible thing to try--we will leave it for last--set has 3 hidden menus and one is OPTION menu which allows a hard reset of entire set--sets everything back to factory except convergence adjustments which are stored in another area.
Apr 06, 2012 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-65809 - works, but screen won't power on.
yes that is correct 12 is normal...make sure all connectors are plugged in and in the correct places . conectors should be marked with letters that match the marking on the circuit board. Then look for heaters , in the glass bottom of the picture tubes(CRTs) there should be a little orange glow visable though the neck of the CRTs just above where the crt boards plugg onto the bottom. if the heaters are not glowing then check your wires to the crt boards again , you probly tugged one of them too hard during disassembly also check for cracked solder in the heater circuit......Oh yeah, you didn't mention -Does the TV get high voltage ??? thats important to having a picture......If you see the heaters glowing when the tv is on then look down into the lenses of the crts . If you see a brite color horizontal line closer to one side in each of them then you know most of the tv is working. If that line is curved then the tv probly detects that the convergence circuit is not working and it is blanking video.
OR -----
the error is 21 (see what number it ends the sequence with..) . Error 21 is X_Ray protect and you probly plugged one of the connectors into the diagnosic connector(near the high voltage transformer- normally nothing goes there) . If that is the case then somthing in the H.V. circuit could have been permanently damaged and now the tv has a new problem and wont work even if you put that connector in the right place.
Oct 09, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Apr 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-A65 Sparks coming from the Bulb Ballast
Your crt is leaking coolant onto the board , you need to rebuild whichever crt's are leaking and fix the board!
Nov 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Mar 05, 2008 | Mitsubishi WS-65313 65" Rear Projection...
When Turned on Picture curved at top and bottom
I would try soldering your convergence amp ICs. Mitsubishi has had some issues with sparse solder at the ICs Dress up the solder a bit and see if this helps. If not you will no doubt need to replace the ICs there are two of them and they cost about 10.00 each. Let me know if you need anything further.
Jan 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
