The washer made it to the rinse cycle and just stopped...timer not advancing anymore. all my clothes are sitting in dirty water. i can cut it off and reset it to the rinse cycle and it will agitate with the dirty water for a while then stop again without draining or changing the water. i can turn it off and set it on the spin cycle and nothing happens at all. jimmy
    Brigadier General:
  • 6,277 Answers
As you have not mentioned the make and model I am having to guess!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 31, 2011
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops at rinse cycle
Hi There,
Sounds like you need a new timer. Hope this helps and thank you for using FixYa!
Mar 30, 2009 | Maytag Washing Machines
Dial doesn't advance to next cycle
if u can advance it manually and it works u need a timer if not probably a lidswitch
Mar 27, 2009 | Maytag Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Won,t drain on rinse cycle
    Ok mc we need a timer at this point. You see the timer doing several steps different than before.
    Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Water not draining out w/ spin cycle
    sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
    Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Front loead washer will not spin/rinse,
    First, make sure that you do not overload the machine.
    When the clothes are wet at the end of a cycle, check these:
    Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
    • If it's spinning when you lift the lid, the coupler is fine.
    • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
    Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
    Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
    Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
    Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
    Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
    70 series Kenmore washer
    POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
    IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
    Mar 31, 2008 | Kenmore 22422 Top Load Washer
    Washing Machines Logo
    15 people viewed this question
    Top Washing Machines Experts
