Question about Hitachi 51UWX20B 51" Rear Projection Television
Colorguns not working color - Hitachi 51UWX20B 51" Rear Projection Television
  • Hitachi Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs thcolorguns not working color - 578ba6c.jpgnged.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 15, 2011
Hi my printer canon mp287 colored ink does'nt print correctly example color blue turns color violet, yellow turns color pink and pink turns color green
Mate take them back where you bought them. They have to replace them. If not working then try where you bought them. If that not work,go to the manufacturer . Take care Aage
Mar 12, 2015 | Canon Office Equipment & Supplies
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My mp240 won't print because it doesn't have a color cartridge. I NEVER print in color! I DO NOT want to print in color EVER! Do I absolutely need to have a color ink cartridge install for it work?
Why would you buy a COLOR printer but only want to print in black & white?? Since its designed to be a color printer, it will only work with both cartridges installed.
Feb 15, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Print server PD-301U can not work in Printer
I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to Epson's Web site, here are the Epson printers it supports (note the TX101 is NOT in the list):
  • Stylus 5700
  • Stylus 5700L
  • Stylus 5800
  • Stylus C60
  • Stylus EPL-5500
  • Stylus EPL-N2000
  • Stylus EPL-N2010
  • Stylus LQ-100
  • Stylus LQ-300
  • Stylus LQ-550
  • Stylus LQ-570+
  • Stylus LQ-1070C+
  • Stylus LQ-2070
  • Stylus LQ-2170C
  • Stylus Color 400
  • Stylus Color 440
  • Stylus Color 460
  • Stylus Color 480
  • Stylus Color 600
  • Stylus Color 640
  • Stylus Color 660
  • Stylus Color 740
  • Stylus Color 800
  • Stylus Color 850
  • Stylus Color 860
  • Stylus Color 900
  • Stylus Color 1160
  • Stylus Color 1500
  • Stylus Color 1520
  • Stylus Color 3000
  • Stylus Photo 700
  • Stylus Photo 710
  • Stylus Photo 750
  • Stylus Photo 870
  • Stylus Photo 1200
  • Stylus Photo 1270
  • Stylus Photo EX
  • Stylus Pro XL
Here is the link to page I am refering to:
http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
May 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Color problem please help
Did you just replace the toners? are you using generic? I have seen some colors off due to generic toners, (could be a bad batch).
Also, there should a be screen in the Menu section where you can try adjusting the color or
Re-calibrate it ( I would try this 1st)
Print out a Demo sheet it will give you a color test sheet how does it look?
I am not a color copier specialist but have worked w/techs that are, but i work on color printers, ususally same principle.
Also look for a screen called Configuration page this will tell you the settings of the copier and may actually tell you if a color is off.
the problem is you have to have a service manual because you are dealing with adjustments on an X-Y plane.
Nov 20, 2008 | Office Equipment & Supplies
No color - tv only
It may be your color tube going out. It has happened to me several times!!!!
Jun 25, 2008 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
Color cartridge
Turn off and unplug your printer from the wall for a few minutes. Plug it back in and turn it on? If that doesn't work, remove the color ink and make sure the contacts on the cartridge are not smudged, reinsert the ink. If that didn't work re-install the old color cartridge and reboot the computer then try to change to the new color. Let me know what happens, Good Luck, Tim
Feb 13, 2007 | Lexmark X83 All-In-One InkJet Printer
Hitachi 51UWX20B 51" Rear Projection Television Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
