Question about NetGear Push2TV TV Adapter for Intel Wireless Display PTV1000
Problem with push2tv I have installed all the software, and allowed all the programs the troubleshooting guide told me to allow through the firewall but I still cannot establish a connection with the adapter. p.s. My laptop meets all the requirements except for two things i am unsure about. They are: the HP dv7 is not listed in the list of compatable computer but it meets all the graphics and processor speeds (i5), and it has a b/g/n wireless card (does does that kind of wireless card work with push2tv?). the error i get is "could not obtain a network address..."
Benimur
  • 6966 Answers
SOURCE: new computer hung at "Acquiring network address"
Verify that the DHCP feature of the router is enabled. Alternately, you may want to set the PC to use static IP configurations rather than "Obtain an IP address automatically". Sometimes WinXP WiFi configuration messes connections when none WEP or WPA is used.
You may want to fix set your PC's WiFi config to IP Add:192.168.1.2; Subnet Mask: 255.255.255.0 and Default Gateway: 192.168..1 (that is of course assuming that your NetGear RangeMax WPN824 Router uses the 192.168.0.1 IP add).
If this still does not work, pls post back so we can figure out tricking the WinXP WiFGi config to connect.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 02, 2007
anandg27
  • 1272 Answers
SOURCE: netgear wpn 111 on windows xp - "connection failed firewalled"
Check what security encryption is being used on the wireless network. Also, if you are using MAC filterning on the wireless network then disable it and then try connecting. Moreover follow the steps below to connect to the wireless network:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Posted on Jun 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: i can not connect new laptop to existing personal wireless networ
unplug router for 10 seconds and plug back in. Then try. If needed, use network setup wizard.
You can also renew your pc's ip address by going to start menu, then run. Then type ipconfig/ release then type ipconfing /renew and everything should be fine.
Posted on Nov 09, 2009
SOURCE: My brand new hpc4780 photo
Hi, i have the same issue and it isnt the firewall. But here is how to disable it if it is. Go to the router websight at 192.168.0.1 (type this directly into the browser bar at the top of your page. The password is usually password in lowercase. The username is admin. This will get you into the management screen for the router config. Look on the Left and you will see firewall. Click on this then ensure that there are no restrictions for HP.
I still have the issue with the printer so good luck.......scotty
Posted on Sep 25, 2010
  • 3 Answers
SOURCE: I'm unable to connect to
Sounds like you have a firewall problem either with the Windows 7 built-in firewall or an anti-virus application firewall. Do you have an Anti Virus program installed?
Posted on Nov 25, 2010
Hau I instaling GPS on my computer and than loagin on my mobailphone?
Installing programs are attainable on computer from where spaces are provided to capture through to displaying. Computer feature functions allow an extensive resourcefulness. In situations that several devices derive network connectivity requires sharing resources is attainable by allowing computer to capture the installation of extensive volume of media from where devices like mobile phone derives remnants of resources from network connections. Reason a factor with computers capturing the host functions are becomes has enough spaces as device to capture the entire volume to material programs. In the circumstance of mobile phones, spaces have least been provided by manufacturer to capture display an enormous program resources like programs. Mobile telephones derive an experience from network structure of computers however captures media in fragments necessary to user experiences. Once the global position program has been installed on computers as local devices, an area network connection of devices of mobile phones derive resources from that computer. Recognize the computer on which program was installed either as local device that sets the structure recognidsable as area from where mobile phone would derive resources. Mobile phones that derive resource from internet devices like World Wide Web least requires ascertaining the location computer from where tour guide feature as map guides are derivable. Phones that have internet world wide web's have browser page programs from where type searching map guides derives to display requested results from any available computer with media.
Feb 27, 2011 | Computers & Internet
Driver for web camera delux
The camere device would have been complement with installation resources from manufacturer once acquired. Observe the resources required installations. For example, the device installation user guide provides procedures to attaining the entire installation on computer. First, connect the camera to the computer. Once achieved the computer response with messahe display that recognises the new devices allowing for another instruction. At which point, computers that allow plug and play would least require an complementary software program to attain functionality. Alternately, a connection of devices on the computer should request to install the require complementary program either located on disk medium or acquirable on the networked structures like an internet. Allow the computer to search and compile the missing details also attainable by activating system updates or upgrades.
Jan 30, 2011 | Computers & Internet
Dropping out
Check the enthernet plug if it is still working, Also try to replace the plug because it might be the cause of dropping out. If it has a driver and If you are using a windows 7 operating system, Follow this guide:
Before you install any program in a windows 7 Operating System Computer . Right Click the Icon of your program installer first then you choose "troubleshoot compatiblity". It will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.
Nov 21, 2010 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Jvc everio software for windows 7
, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D julyallan01_15.jpg
Nov 13, 2010 | JVC GZMG150US Hybrid Camcorder Sd Or Hdd...
Where can i get a windows7 compatible printer software?
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))julyallan01_31.jpg
Oct 25, 2010 | Compaq Inkjet IJ600 Printer
Software for the ZR200 for Windows 7
Maybe, It doesn't work because the driver you installed. It is for other versions of operating system. I am also using windows 7 like you.Dont worry, You can still use your old julyallan01_1.jpginstaller/driver from other versions of operating systems. Before you installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D
Oct 22, 2010 | Canon ZR200 Mini DV Digital Camcorder
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
Printer offline. How do I fix
The issue is with the printer ports, we need to configure the ports for the network from the printer icon.
Please perform the following troubleshooting steps to fix the issue.
1.Start, Control Panel, and then select Printer and Faxes.
2.Click File and then click Server Properties.
3.Select the Ports tab, and then click Add Port.
4.Select TCP/IP Port and create a new port.
5.Type the IP address of the Printer(which is printed in the network configuration page) and proceed with the onscreen instructions.
Follow these steps to unblock the HP programs and the required Internet ports.
Open the C:\program files\HP\digital imaging\bin directory and then locate the following files:
  1. hpoews01.exe
  • hpofxm08.exe
  • hposid01.exe
  • hpqkygrp.exe
  • hpqste08.exe
  • hpqtra08.exe
  • hposfx08.exe
  • If the HP software installed on the computer is version 10.0 or newer, find the hpiscnapp.exe file.
  • If the HP software installed on the computer is version 9.0 or older, find the hpqscnvw.exe file.
Open the C:\windows\system32 directory and then locate the following files:
  • hpzwiz01.exe
  • hpznui01.exe
Make a note of or copy the file path for each file listed. The file paths should resemble the example: C:\windows\system32\hpzipm12.exe .
In the firewall software, make sure that each of these programs displays in the list of trusted or allowed programs. If any of the programs do not appear in the list of trusted or allowed programs, add the missing programs to the list manually
NOTE: The name of the list might vary, depending on the firewall program
If the firewall software has different trust levels or requires specific permission for a program to access the Internet, make sure you allow each of the HP programs to access the Internet freely.
Click OK or Save to save the changes to the trusted or allowed program list.
Jan 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have Micrographx Picture pubisher 8 and just changed to new PC Windows 7. Now I am being told that Win7 is not compatible! Can you help please? Regards Peter
yes can be, just follow these steps:
Dec 05, 2009 | Micrografx Picture Publisher 8.0 for PC
IT DOESNT ALLOW PRINTING AS IT SAYS "unable to print review users guide troubleshooting' HOW COULD I SOLVE THIS PROBLEM
Did you install the drivers correctly?
What program are you using?
How are you trying to print?
Are all the cables plugged in?
Is the printer on?
Sep 25, 2009 | Brother MFC-9440CN Laser Printer
NetGear Push2TV TV Adapter for Intel Wireless Display PTV1000 Logo
1,091 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
