I. have gateway T siries lot top but it doesent, tur on.is completet dead. ahwat to be seen the problem.
    Problem Solver:
  • 13 Answers
Check to see it is plugged into the outlet, battery may be dead, check to see the outlet has power, and the power cord is working.
if you are confident you can, then open the laptop casing and make sure there are no broken or loose connections, then reclose it.
Posted on Mar 31, 2011
When I try to engage Siri she says she cannot make the connection and I should try again later. I have iOS 10.0.2 installed. I have shut it off and restarted but the problem remains
Siri troubleshooting: Siri's not working at all on my device. Which iPhone/iPad models can run Siri? If Siri isn't working for you, the first thing to check is your model of iPad or iPhone - older devices can't run Siri, even if they update to a newer version of iOS. Siri is available on the iPhone 4s and later, on the iPad 3, iPad 4, and all iPad Pro, iPadAir and iPad mini models, and on the 5th- and 6th-gen iPod touch models. Plus the Apple Watch and 4th-gen Apple TV, of course Siri troubleshooting: How to turn Siri on If it's not working at all, Siri might be switched off. Go to Settings > General > Siri and make sure the top slider (next to Siri) is on, and green.
Sep 29, 2016 | Apple iPad Tablets & eReaders
Iphone 6 plus siri isnt working
Enable it in settings
Feb 27, 2016 | Cell Phones
How to get siri on ipad2 ios 8.1.2
How to configure Siri
  1. Launch the Settings app on your iPhone or iPad.
  2. Tap on General.
  3. Tap on Siri.
  4. Tap on Language to change languages and dialects.
  5. Tap on Voice Feedback to choose whether Siri always talks back to you, or only when in Handsfree mode.
  6. Tap **My Info* to select your Contact card so Siri knows who you are, what your numbers are, and what your locations are. This lets you say things like "Call home." or "Give me directions to work."
  7. Toggle Raise to Speak to have Siri pop up whenever you bring your iPhone to your ear, and you're not on a call. This may drain your battery faster than if it were disabled.
25337929-32tv5p3i4t34gwsttnmh0d03-5-2.jpg 25337929-32tv5p3i4t34gwsttnmh0d03-5-5.jpg http://www.imore.com/how-set-configure-secure-and-start-using-siri#siri-enable
Dec 25, 2014 | Apple Ipad2 32GB Wifi
How do I disable Siri, please on my iPad. I have follows the usual steps that do not work. A black outline box circles all commands, so Siri refuses to run off.
Restore it by holding down home key and top button until apple returns to screen. If that doesn't work back it up and restore it as new. Don't turn spotlight or Siri settings on ever, wastes data and tracks your cell
Sep 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do I make Siri listen...now, Siri says "sorry, I didn't get that. No chance to ask the question.
Try using it in a quiet place without a lot of background noise or loud music playing, and don't clear your throat or cough, etc. before speaking, just start right in.
Aug 12, 2014 | Apple iPad Tablets & eReaders
Iphone4 dead after jailbreak
you need to open phone and remove motherboard away from the battery and when phone back on do a reset with the home volume down button and power. and put back on original apple software siri app has low level control but also has high level control apple software only allows it to use low low level. jailbreak phone allows both and this is why your phone is dead. doing this can work but its 50-50. as the app and others can do damage if it changes the volts to the processor. if it has you will need another motherboard.
Feb 22, 2013 | Apple iPhone4 4G iPhone 4
Push power button it lights up for 3second then shuts off what is wrong with it
Could be bad ac adapter or bad motherboard. Have seen lots of cases where the ac adapter was bad and the laptop no longer starts after the battery goes dead.
Jan 10, 2013 | Gateway M360 M460 M680 MA2 MA3 MA7 CD DVD...
Gateway GM5472 won't boot no power
No power and won't boot suggest a power supply problem in the tower--it is listed as a desktop unit.
What is common on a lot of units (computer towers, TV sets, you name it) is the stand by power supply which is on 7/24 fails.
The most common reason is filter caps dry out because cheap ones and ones rated too low a voltage are used.
The beauty of this is if the power supply is removed and opened you will be able to SEE the bad ones.
I will attach a photo of bad caps--tops which should be perfectly flat are puffed up from a little to a lot and or brown material is seen at top and bottom of the cap.
I have fixed many towers (desktop units) and other equipment with this problem---most of them at first had to be turned on a few times to get them to come on--it gradually gets worse until it will not make it on.
If bad caps are found you can usually buy a replacement supply at a reasonable price or replace the puffed up caps (seen as many as 8 bad in one computer tower).
This answer is based on the information you provided in your question and the answer from personal experience.
SD TECH
4_25_2012_5_11_26_pm.jpg the two larger ones are bad for sure.
Apr 25, 2012 | Gateway GT5220 PC Desktop
Is there is siri for lap tops
No there is not, Siri is the voice controlled personal assistant application for the iOS and as such, is not available on your PC.
Dec 18, 2011 | Toshiba Satellite E205-S1904 Laptop
My golf cut out as driving along and refuses to start its not cambelt engine turs as normal but will not fire
Check if the distrebuter is creating a spark by unplugging one of the plug leads and holding it close to the engin block to see if the spark jumps from the lead to the block if it doesent then the problem is with the distrebutor. when last did you replace you spark plugs?
Mar 29, 2010 | 1993 Volkswagen Golf
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
