Question about Cuisinart DCC-1200 Coffee Maker
Should I leave the water inside the coffemaker?
    Sergeant:
    Champion:
  • 422 Answers
Yes you can, it doesn't do harm because it has thick aluminum canister that store water inside. But if you worry about that it may harm your unit then it is worth drain the water and put it when you brewing coffee.
I hope this advice help you.
Posted on Mar 31, 2011
My bunn coffemaker has water leaking out from under the bottom when I close door and it starts to brew.
* tank overfilling. Shock hazard! Unplug. Check warranty. Call vendor for service or replacement.
* probably a leaking tank, valve, level probe, have tech check.
Aloha, ukeboy57
Jan 03, 2017 | Bunn Coffee Makers & Espresso Machines
I now use soft, filtered water each day. The "descale" message still comes up every 60 days. Is descaling that frequently, normal?
yes you will still need to descale it
soft filtered water still contains minerals and calcium but in lesser quantities
if you wish to avoid descaling use distilled water or demineralized water
Sep 18, 2016 | Breville Coffee Makers & Espresso Machines
How do i clean the coffemaker without a self clean button
I usually use some white vinegar and water mix and run it through the system. Be sure to use just plain water for a second rinse.
Mar 05, 2015 | Coffee Makers & Espresso Machines
My coffemaker doesn't hold the water and is coming out from the bottom
This is generally a non-fixable issue. I had this with at least 2 coffee makers. It would be best just to buy a new one.
Oct 11, 2011 | Cuisinart DCC-1200 Coffee Maker
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
My coffemaker won't brew
Adequate power and everything in place? Ck for any inconspicuos switches. My coffee pot has two.
Aug 26, 2009 | Black & Decker DCM2775
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
Mar 26, 2009 | Cuisinart Coffee Makers & Espresso...
What is the best way to clean my cuisinart coffee maker?
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
How can I set the automatic timer on the Krups FME2 Coffemaker
Problem solved...
Found the manual for my coffemaker online
Dec 15, 2008 | Krups FME2 Coffee Maker
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
