Question about RCA DRC7005N DVD Recorder
It shows "Fan Fail" and
    Top Expert:
  • RCA Master
  • 75,289 Answers
Hello
The failure is of fan only, fan may be damaged. It can be replaced with and other fan. take it out, and go for an other same type. If the whole system is dead, it should be due to the fault of its power inverter board, and should be ckecked well. If power board has some trouble, front panel display also will not be there or display will be present, but no other functions, like load disc or unload disc, play etc won't work. From these make sure which part has the trouble and go on. You have pointe out the fault of the fan only here. OK.
Posted on Mar 31, 2011
Can't boot,showing "no bootable device,hit any key
Take it to an IT specialist as I suspect the hard drive may be dead.
May 19, 2013 | Computers & Internet
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
My camera doesn't work on my Toshiba satellite A215-S7413
Please disconnect the cam and remove the cam software from the computer and re install the cam software and connect he device and check it.
Mar 17, 2012 | Lifetime Toshiba Satellite A215S7413...
Hello The light, the grill, top cooling fan and main circulation fan all work but the oven doesn't heat up at all. So I assume it's the main element - but isn't there more than one main element...
Yes it does mean that there is a base element, but more likely to be fan element, possibly base element may require replacing as well.
Oct 27, 2010 | Ovens
Replace cooling fan termstat and vehicle still over heats
Thermostat
Test thermostat in a jug and pour boiling water on it , it should compress meaning it works. Check that the waterpunp is operating pushing water into the engine .Check that radiator water flows to the watrpump. Is tension of fanbelt of waterpump sufficient that it doenst slip. Lastly check that the radiator fan is working if has a electric fan. if this doesn’t help check if radiator or engine water passages isn’t blocked.
Aug 29, 2009 | 1995 Pontiac Sunfire
RCA DRC7005N DVD Recorder Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
