Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Error 99 When I am outside and trying to take a pic I get this error. What is it?
WHAT IS THE SOLUION OF ERROR 99
Posted on Jan 28, 2011
  • 81 Answers
Read this article:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Posted on Sep 01, 2008
My casio exilim camera is showing card error con't take pic, pls help me.
can you mention what is the type of SD card used ?
brand -
speed -
rating -
capacity -
also if that SD Card works well outside on laptop or mobile ?
Jun 08, 2016 | Casio Exilim Ex-zs5 14.1mp Digital Camera...
Err99 when taking pics in sun. Taking in side with flash fine, pics outside at night are fine?
Error code 99 indicates detection of a system malfunction. Try switching on the camera and while it is still switched on remove the battery. Leave it for about 30 secs then re-insert the battery once powered up switch the camera off wait 30 secs then switch it on again. This action sometimes will remedy this problem but failing that it may need a visit to the repair shop.
Sep 20, 2014 | Canon EOS-20D Digital Camera
I'm getting an ERROR 99 message when I turn my Canon SLR on. I've tried changing the battery, cleaning the lens and powering the camera off and on but I'm still receiving the same error. Any solutions?
see to it there's no jam on parts mechanism inside, it need to reset to authorized service center or find reset button on the unit but not all slr have it outside some are located inside some dont have it
Feb 12, 2011 | Canon EOS 5000 35mm Film Camera
I'm getting a CF error on my Rebel XT.
Check the pins inside the card chamber...is one of them bent?
Jan 01, 2010 | Canon Rebel XT / EOS 350D Digital Camera
What is error 99
What wide angle lens is it need f number it may be to old to work on eos 400d
Dec 27, 2009 | Canon EOS 400D Digital Camera
Error 99
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Mar 16, 2009 | Canon EOS 40D Digital Camera with 17-85mm...
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error 99 in body
Jul 07, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Quantary Tech-10 75-300mm use with Canon Rebel XTi
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Mar 12, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Error99... pls help!!
here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
Feb 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
287 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
