Question about White Sewing 1740 Mechanical Sewing Machine
The small bar that holds the zipper foot on broke. How can I get a new zipper foot?
  • White Sewing Master
  • 5,129 Answers
There will be several zipper feet available at any of the sewing machine stores. You can either take the broken foot with you (or another foot for the machine) or note the shank length and the bar length on the foot. I believe the White uses a low shank foot. In that case, you would get a foot that is designed as a low shank foot (assuming the bar isn't narrower than your current foot), and it will work.
The common Foot styles are low, high and slant.
I hope this helps.
(you can also order sewing machine feet online but you need to know the style of how the foot connects to the machine. The easiest way to do that is to compare it to similar feet in a local store. Most of the online vendors will list the machine brands that are compatible with a given foot. However, I know that Husqvarna low shank feet have changed width over the past 30 years and thus not all of the feet from a new machine are mutually compatible with those for an older machine. So I wouldn't guarantee the match without seeing the feet side by side.)
Posted on Mar 31, 2011
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
As soon as I put on a zipper foot the tension on my ddl 5550 loosens. when I put on the regularfoot its fine. anyone else having this issue?
The 'shank' on your zipper foot is too long and is holding your upper tension open. When I get a rogue foot like this, I set my old foot and my new foot, side by side on a flat surface and measure the height from the surface to the bottom of the hole where the foot is screwed onto the presser bar. When I see how much difference there is, I mark it and take my Dremel and cut the hole lower on the new foot. This will usually fix the problem. The only other thing you can do is to adjust the height of your presser bar to accommodate the zipper foot but now it won't fit your regular foot so you have a new problem. :)
Aug 01, 2015 | Juki DDL-5550 Industrial Straight Stitch...
Iwant to sew a separating zipper on a coat. what does the zipper foot look like for singer model 3116?
Just like the regular working foot, most zipper feet look the same regardless of machine. At least, the part of the foot that is actually in contact with the work: small, solid--no thread slot or needle well in the middle--and a small notch on each of the left and right sides.
Jul 16, 2014 | Singer 3116 Simple
Problem attaching zipper foot
thanks for letting us know
Apr 17, 2014 | Singer 8763 Curvy
Zipper presser foot
Is it fitted correctly? Some of these feet need to be helped a little to get them to snap into place. (press down on the presser foot bar)
Aug 09, 2012 | Singer Confidence 7463 Computerized Sewing...
How to attach zipper foot on singer inspiration
Here is a copy of your manual.
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Most modern machines have snap off and snap on feet. Grasp the foot that is on there and push down. Then while lowering the foot, align the little bar on the zipper foot and watch it snap in. Easy.
Jul 07, 2012 | Singer Inspiration 4205 Mechanical Sewing...
Got bernina 1015 sport sewing machinewith one foot want to buy zip,buttonhole &overlock foot is ther a special number or do all bernina feet fit al types of bernina machines
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Jul 24, 2011 | Sewing Machines
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
White Sewing 1740 Mechanical Sewing Machine Logo
76 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
