Question about Microsoft Xbox 360 Console
My xbox 360 is making clicking noises, vibrates alot, and is extreamly loude while running, i think its the fan in it but im not sure, so what should i do?
  • 767 Answers
Hi Charles
There are several reasons your console is noise , First remove your game and
listen and see if the noise is reduced also the vibration should stop too.
I have seen or heard rather this before . The cause was a the drive spindle
hub some how got skew so the disk wobbled as it was spinning.
The fix was simply to replace the hub/spindel motor .
The rattling sound may be from the tilt switch or pieces of plastic
bouncing around . you will have to open your console to remove the
the small chunks of plastic + blowing it out will help cooling also.
The fan should not make that much noise . If it seems to be loud
then you may need to replace the heat sink compound on the G.P.U.
and the C.P.U.
if you have any questions feel free to ask.
Rob
Posted on Mar 31, 2011
New x-box makes alot of noise ,eg clicking and loud humming .friends new console is alot quieter
You could try taking it back to the store and exchanging it. There is not alot of moving parts in there just the DVD and fans on the back of the unit. I suspect the fans. They offer replacement fans but if it is new your best bet is to exchange it. But, use memory cards to copy off your save games, etc.
Jan 01, 2010 | Microsoft Xbox 360 Console
Why is my system running so loud?
The 2 most common causes of noise are the DVD drive and the fans.
If it does it continuously, check the fans. Make sure you are giving it adequate ventilation (atleast 12 inches in the back and 3-4 on the sides minimum) because if the fans are running that loud it's an indication that your 360 is running hotter than it should. If it only starts happening when you insert a game/dvd disk it could be the DVD drives motor running harder. This is a more complex issue to tackle and not recommended for the unexperienced. The only simple trick I can think of at the moment with the DVD drive is to change the consoles position, if it's vertical, lay it down and vice versa. Hope this helps or atleast narrows it down for you.
Dec 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 is loud - sounds like a loud fan motor. How can I make it run quietly?
You can try installing the game you want to play on the Xbox 360 Hard Disk, which reduces the motor noise to an extent, however there is no permanent way to fix the loud fan motor noise while playing the game with the disk in the drive.
Make sure you keep your Xbox 360 unit well ventilated, ensure it does not gather dust near the small vents and openings on the unit.
Regards
KreativeGeek
Dec 26, 2009 | Microsoft Xbox 360 Console
Why does my xbox make a loud humming noise when I close the disk tray with a disk in it and when it is loading?
im pretty sure thats just the inner workings of the xbox. my friend's xbox does that to, along with my wii
Dec 02, 2009 | Microsoft Xbox 360 Console
What to do when da game console is making noises
What type of noise's ? loud ? like somethings loose ? Just buy an external fan if it runs loud
Oct 25, 2009 | Microsoft Xbox 360 Console
Why does our xbox 360 make so much noise when running
The possible and most likely culprit is that after a while the inside of your 360 collects alot of dust and that dust builds up inside and on your fan. So I suggest you goto any local Walmart, kMart, Computer Store and purchase a can of that compressed air and use that to blow the dust out. Do not use a regular compressor because condensation builds up inside the compressor and will blow alot of water into your system and if you blow water in your 360 and plug it in you are going to have bigger problems than a noisy fan. The best fix is to actually open the case and clean it out that way. But by doing this you Void your warranty with Microsoft. So that is on you.
Sep 28, 2009 | Microsoft Xbox 360 Arcade
Hey there guys i know this reset thing is sucky i havent resolved this but i have a weird solution i myself moded my xbox after the warrenty was long gone ive had my same xbox for almost 5 yeaars im always...
if you want to ,you can take some computer cpu fans with the fat end and splice a power cable or use a corded fan that snapps onto the existing connector and have lots of fans in the 360.the cooler it is the better and faster it will run.this will also help to prevent the red ring of death.the harddrive makes noise because of a disbalannce of the magents.if a loud clanking accurs then the harddrive is going bad and need replaced.the fans are probably slower because of the bearing is bad.if they are slow and don't put out much air and they vibrate when ran then they need replaced.if you got any questions please email me at gamecrazy944@yahoo.com
Jun 27, 2009 | Microsoft Xbox 360 Console
To loud
I can't really tell you whether or not yours is unusually loud without hearing it, but Xbox 360s are known for being very loud consoles.
May 09, 2009 | Microsoft Xbox 360 Console
Loud humming noise coming from 360
The loud humming noise is usually the DVD drive. It is very fast but is very loud. If you have the NXE dashboard you can download games to you Xbox 360 to run them from the hard drive (you will still need to put in the disk for copy protection issues). The Xbox should make less noise then. Try to mount the Xbox 360 on a hard surface which is in contact with a soft floor to reduce the noise travelling through your home.
If it is making a loud noise while there is no disk in the drive then take the console to a Microsoft dealer whenever you can to have them take a look at it.
Feb 13, 2009 | Microsoft Xbox 360 Console
Xbox 360 makes revving sound when starting and loading
It's not likely to be the fans. The DVD drive makes a loud whirring noise. If you have the NXE dashboard you can install games to the hard drive so the DVD doesn't have to get up to speed, which means the Xbox will be quieter and you'll have faster loading times.
Feb 06, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
145 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
