I have Linksys WRT 150N. I need to know where in the setup I find how to change the key code
    Master:
  • 397 Answers
If you are talking about the wireless encryption key it is under the Wireless heading under Wireless Security.
The default IP address of your router should be 192.168.1.1
Posted on Aug 05, 2008
I have a linksys wrt 150n router. i've connected my imac wirelessly, but cannot get my pc-laptop to connect. what am i doing wrong? yes, it is secured with a password.
hi parkerjunkma,
be sure you detected the wrt..then the SSID and Security Encryption should be matched..the SSID will definitely detected so the Password should be entered.
mastergani
Dec 28, 2010 | Linksys Wireless-N WRT150N Router
Hi, I configured my Linksys WRT 150N Router to block certain URLs. I get the sites blocked on some machines running Windows XP while I cant get the same sites blocked on some running the same XP. Its even...
I was having a similar problem, and solved it by upgrading the firmware of my router. Once I did the firmware upgrade, blocking worked fine. You can get the firmware upgrade by going to the Linksys website, clicking on Support, and then specifying your router model number.
Dec 15, 2010 | Computers & Internet
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
How do i secure my linksys WRT 150N?
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 09, 2009 | Linksys Wireless-N WRT150N Router
How to secure N WRT 150N Router
enable wep or wpa or wpa2 encryption in the wireless settings.
Nov 04, 2009 | Linksys Wireless-N WRT150N Router
I have a WRT 150N wireless router. it is not putting out a network but i can connect to the internet with one of the lan line ports
Connect to the router via the admin screen and select the wireless tab. Check to see if wireless is set to disable or to a setting that is not compatable with your PC/laptop wireless card.
Hope that helps and thanks for using FixYa
Mar 07, 2009 | Linksys Wireless-N WRT150N Router
Version 1.1 internet works for 5 min and stops.
First thing to do here is to reset the router and reconfigure it back using the setup CD and hopefully it will reconfigure the router but if still didn't not make it work better call Linksys tech support and let one of their tech to walk you through it checking the router and also updating the software for it , they are open 24/7 this is the number 8003267114...
Hope that helps..............
Sep 18, 2008 | Linksys Wireless-N WRT150N Router
Lynksis wrt150n .. setting
Log in to your router and select the wireless tab. Then click on wireless security. Set your security mode, encryption type and create a key that will be needed to connect to the router wirelessly. Administration tab should be right next to status tab.
May 14, 2008 | Linksys Wireless-N WRT150N Router
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Nov 24, 2007 | Linksys WRT300N Wireless Router
Computers & Internet Logo
David Payne
David Payne
