Question about Alpine CDA-7894 CD Player
Model 7894. front face does not light up - Alpine CDA-7894 CD Player
I am installing the unit and the readout says "Interrupt"?
Manual states to be sure to press the reset button when you first install and after replacing battery. Online manual at http://vault.alpine-usa.com/products/documents/OM_CDA-7894.PDF
May 27, 2014 | Alpine CDA-7894 CD Player
Was handed down an alpine cda-7894 and have no manual or wiring diagram. just need to know what the wires are
Hello, I was able to download the manual - email me bellmaneng@yahoo.com if you still need the manual!
Dec 30, 2010 | Alpine CDA-7894 CD Player
Does the Alpine CDA-7894 have a fan built in the rear of radio? Would it be visible? I see the opening but no fan. I am curious if this is normal for the CDA-7894. Every Alpine i have ever owned had a fan...
Hi my names Josh i was reading some info on your unit. Thats a very nice unit was made in 03 and had alot of really nice features on it however if your looking for fan that unit was not equiped with one that slot in the back is not actually a fan but part of back plate design of the unit.
Mar 06, 2010 | Alpine CDA-7894 CD Player
Install CDrom hardware
There are several Gateway case models. I think most of them you have to take the side panels off and the face hss some pins or straps that enter the inside of the case through the front of the computer and latch into the main case. Once you remove the sides then you can see them on all four corners. You just need to put the outward pressure on the housing face and then push the latch to the side with a screwdriver to release them.
Nov 23, 2009 | Computers & Internet
Wiring
In some installations it is not used.
Reply with your vehicle model/make/year and I can tell you the wire in the vehicle.
You can simply terminate the wire and it will be on full bright all the time.
It works in conjunction to dim with your dash lights at night. That is its sole purpose.
Thanks for using FixYa - a 4 thumb rating is appreciated for answering your FREE question.
Aug 20, 2009 | Alpine CDA-7894 CD Player
Sony reciever model strdg800 the face does not light up
This can be as simple as poor connection on the display itself or a problem in the power supply. Look carefully at the connections for the diplay panel on the PC board attached to the front face of the unit. Specifically, look at the pins on either end. If those look grainy or have rings, then most likely the display is not getting powered. Resolder those pins and let me know what happens. That may resolve the problem.
Dan
Feb 17, 2009 | Sony STR-DE598 Receiver
CDA-7894 ALPINE CD CAR STEREO NO SOUND JUST POPS
ic needs changeing on the menu if its had an amp added the stereo swiches over u can do it manualy i c in the menu or connect an amp...
Apr 18, 2008 | Alpine CDA-7894 CD Player
Tyring to adjust the clock
According to the users manual, which is here;
1) In Clock Priority Mode, press and hold the CLK button for at least 3 seconds while the time is displayed. Time indication will blink.
2) Turn the Rotary Encoder to adjust the hours while the time indication is blinking.
3) When the hour has been adjusted, press the Rotary Encoder.
4) Turn the Rotary Encoder to adjust the minutes while the time indication is blinking. The time is automatically set 5 seconds anter the minute adjustment. The time can also be manually set by pressing the Rotary Encoder.
Best of Luck.
Oct 27, 2007 | Alpine CDA-7894 CD Player
Alpine CDA-7894 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
