Question about ASUS Eee PC 900 PC Notebook
Attempted to restore my daughters pc (asus, model 1001P) after she down loaded the imesh program. Now all it says after it reboots is error.
    Problem Solver:
  • 9 Answers
Unable the imesh prog by the task manager
right click on the taskbar and click tsk manager
Posted on Mar 31, 2011
How do I remove imesh and all its components
Taken from the iMesh FAQ
Error Message: "Unable to find install.log"
You may be receiving this message when uninstalling iMesh. It is usually caused by multiple installs and uninstalls due to troubleshooting and other random fiddling.
This is probably the easiest to solve problem though, so not to worry:
This error occurs during the uninstall process, and causes the uninstall to fail.
First open iMesh, click File, and then click Exit. This will make sure that iMesh is completely shut down before proceeding.
Next, instead of uninstalling, go to the www.iMesh.com homepage, and install the latest version of iMesh by downloading iMesh. This will overwrite the one that you presently have installed.
When completing the iMesh installation, uncheck the run iMesh now option, and then click Finish.
Now that that's done, you may proceed to uninstalling iMesh from the Windows Control Panel as previously attempted, and it should successfully uninstall this time. Source(s): http://www.imesh.com/helpTech.html#5
Jun 28, 2012 | Dell Inspiron 1100 Notebook
Hello I have a asus 1001p netbook that doesn't
Sounds like a job for a repair shop that can attach an external drive to it and reload the operating system.
May 09, 2012 | ASUS Computers & Internet
Asus eee pc 1001p - hard drive failure?
or check the bios settings . look in to which drive is the first drive
Jan 10, 2018 | ASUS Eee PC 1001P Netbook
Unable to restore
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Nov 26, 2011 | ASUS Eee PC 1001P Netbook
My notebook is having trouble to start up. Something to do with bootdriver having issues,how can I solve ?
HI. Welcome to Fixya. Restore from the Recovery Partition
  • Start your netbook and tap the F9 key on your keyboard until you see a loading screen.
  • The restore program prepares the files needed for the operation.
  • A message appears asking if you want to perform the operation, you will lose all files on your computer.
  • Confirm by clicking .
  • This will restore your netbook to factory settings and without any action on your part. Finally we should rather say the Ghost.
  • At the end of the operation, the netbook will reboot on its own, and finish these configurations.
  • A reboot is performed again, and you're on the setup process of Windows as the first boot after buying the netbook.
Hope this resolved your issue.
Thanks for contacting Fixya. Bye for now.
Jul 16, 2011 | ASUS Eee PC 1001P Netbook
I lost my recovery partation and I don't have a recovery cd for an asus seashell eee 1001p, how can I do?
Hi you will need skillful guy to restore your PC Operating system if you had reformatted your hard drive. To restore your O/S without having your recovery CD is to ask from your vendor a copy of it and re-install again. You can do it by having an external DVD driver, change the boot sequence in start up and presto you can reload again your O/S and other applications. Don't forget btw to load the driver in order your PC to work properly.
Jun 21, 2011 | ASUS Eee PC 1001P Netbook
The screen for my asus eee pc 1001p is black, and i cant see anything. I can hear the sounds, but can't see what im doing. I think i set the view mode to mobile, and now i cant change it back. is there a...
Reboot Pc and after it passes the motherboard devices (thats just before you WindowsXP start to load) start pressing F8.Then you will be prompted to a series of boot options.
Select Safe mode.
Once done booting and the message that you are working in safe mode appears,Right click anywhere on desktop ( not over shortcuts) and select properties.Select Advanced.There you should see a varies of selections depending on your video card.
Adjust the video properties you want to have and you are ready
Apr 07, 2011 | ASUS Eee PC 1001P Netbook
Hi, I owned a asus 1001P netbook, whenever i boot it up, it will freeze the at desktop screen and there is nothing i could do.
Welcome to Fixya
Freezing up issues usually caused by recent software installation, hardware modification or virus infection. Try to restore the computer back to the date where it is working fine as part of the basic torubleshooting. Power on the computer and keep on tapping F8 key. Select SAFE MODE then press enter. Once you are inside windows safe mode, click start menu then click all programs. Click accessories then click sytem tools. Click system restore then select a date where you remember your computer is working fine. Hope this helps.
Please let me know if you have further questions.
Thank you for using Fixya!
Mar 26, 2011 | ASUS Eee PC 1001P Netbook
I want to uninstall worthless imesh
1 open task manager, kill of imesh process (or right click on the imesh icon at bottom right corner beside clock and EXIT
2 go to start -> control panel -> Add Remove Programs (or Programs and features) -> find iMesh in the list -> right click -> uninstall
Mar 08, 2011 | Computers & Internet
How do I restore my asus eeepc1001 series to factory default?
The Asus EEE units come with a Restore Disc. all you will need to do is plug in an EXTERNAL USB CD/DVD DRIVE, and load the disc on bootup (cold start) it should start running the recovery for you and will destroy all data on the drive. If you dont have your Restore Cd anymore asus did have a few models on the net for download ar you can request a restore cd from ASUS.COM under the contact us page
Hope this helps
Feb 15, 2011 | ASUS Eee PC 1001P Netbook
ASUS Eee PC 900  PC Notebook Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
